Technique(s) for converting integer to ascii bit pattern in pasm?
grahamreitz
This has probably been answered before. Although, I didn't see anything with a quick forum search.
What techniques are used to convert an integer, stored in a cog register, into an ascii bit pattern, for the purpose of sending it to a terminal, such as the Parallax Serial Terminal?
graham
graham
If you don't mind me parroting the algorithm:
1) Number in a cog register #1 is 123
2) 123/10 = 12r3, store 3 in register #2, 12 in register #1
3) 12/10 = 1r2, store 2 in register #3, 1 in register #1
4) 1/10 = 0r1, store 1 in register #4, 0 in register #1
5) End.
I see that there is a modulus operator in pasm, '//'. Although, does it only work on constants and not registers?
From manual:
"NOTE: All operators shown are constant expression operators."
I was looking for example syntax of the binary operators in pasm, but only saw spin examples.
Would this work?
Post Edited (greitz) : 8/21/2009 9:35:47 PM GMT
dec_to_ASCII 'Converts a number in a register to an ASCII value 't1 - The decimal number 't2 - The current count of the digits (ie, how many 100's are in 843) 't3 - The decimal number address 't4 - (parameter) the number to convert 't5 - (parameter) the number of digits in the number (modified) ' ---too few will result in tuncation of lower digits 'ASCII_num - (result) will contain the number, optional negative (-, counts as digit) 'note: currently, if the number is too large for the specified number of digits, a nonsense answer will be generated in the highest digit. 'Negative not implemented right now mov t3, #decimal add t3, #10 'go to end of decimal list sub t3, t5 'step back the number of digits movs :d_t_a_loop, t3 mov t2, #0 movd :d_t_a_loop_s, #ASCII_num :d_t_a_loop mov t1, 0-0 cmp t4, t1 wc if_nc add t2, #1 if_nc sub t4, t1 if_nc jmp #:d_t_a_loop add t2, #48 :d_t_a_loop_s mov 0-0, t2 add :d_t_a_loop, #1 mov t2, #0 add :d_t_a_loop_s, destination_mask djnz t5, #:d_t_a_loop dec_to_ASCII_ret retIt's not really all that clear, but from what I've seen so far it works on positive numbers.
BTW, your code snippet above won't work, since operators in PASM are constant (compile time) only.
The proper division routine is a bit quicker but takes 30 or 40 longs of COG RAM. It's a lot easier in x86 where the processor does division for you; that's in the PASM instruction set but it's not implemented in the Prop I.
