passing arrays to assembly and back
How can I pass an array to assembly and back? I want to read several ports, place the values in an array and do something with them once back in spin code.
Swampie777
Swampie777
if you have a single array you can give its address as the par of the cognew statement
cognew(@work, @array)
in the cog you need to use self modifying code, and the movs, or movd for move source and move destination. an example of this is
mov hub_array_pointer, par mov cog_array_pointer, #cog_array ' the # symbol gives the cog address of that data :loop movd :next, cog_array_pointer add cog_array_pointer, #1 ' you add 1 to cog addresses since the register is longs :next rdlong 0-0, hub_array_pointer add hub_array_pointer, #4 ' you add 4 for the hub because its addresses are bit sized, so you need to go 4 bits forward to get to the next long jmp #:loopcog_array long 0[noparse][[/noparse]10]
you have to have the :loop separated from : next by one instruction because the data from the next instruction is loaded before the current instruction finishes
for retrieving code from the hub you will use movd because the cog is your destination, for manipulating the data in the cog you will use movs because the cog is your source. then for sending back to the hub you will use movd again because hub operations are strange and the hub address is always in the source field.
for more look at page 21 of the pdf attached here http://forums.parallax.com/forums/default.aspx?f=25&m=209237
Post Edited (Alsowolfman) : 8/21/2009 8:24:53 PM GMT
In my current application I'm reading two pins for a high level, recording the clock counts by difference( one at a time) and trying to pass the results back to spin. I have the spin code in a loop to grab 16 values. I get 16 unique first values, and 16 copies of the first second value.
{{ dual-pulse-read.spin }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long stack[noparse][[/noparse]72] long xxx1[noparse][[/noparse]2] long iii long Idx long xsum long iii2 long xsum2 long Cog OBJ Num : "Numbers" TV : "TV_Terminal" vp : "Conduit" PUB Main xxx1[noparse][[/noparse]0] := -1 Idx :=0 xxx1[noparse][[/noparse]1] := -1 vp.share(@xxx1,@Cog) Num.Init 'Initialize Numbers TV.Start(12) 'Start TV Terminal Cog := cognew(@pulse_,@xxx1) ' TV.Str(Num.ToStr(Cog, Num#DDEC)) ' TV.Out(13) repeat while Idx < 16 xxx1[noparse][[/noparse]0] := -1 repeat while xxx1[noparse][[/noparse]0] == -1 if Idx > 0 TV.Str(Num.ToStr(xxx1[noparse][[/noparse]0], Num#DDEC)) '/*TV.Out(13) */ TV.Str(Num.ToStr(xxx1[noparse][[/noparse]1], Num#DDEC)) TV.Out(13) Idx++ cogstop(Cog) DAT pulse_ org 0 :loop waitpeq zero,mask waitpne zero,mask mov xx1, cnt waitpeq zero,mask mov yy1, cnt sub yy1, xx1 wrlong yy1, PAR add parplus4, PAR waitpeq zero,mask2 waitpne zero,mask2 mov xx2, cnt waitpeq zero,mask2 mov yy2, cnt sub yy2, xx2 wrlong yy2,parplus4 :here jmp #:loop zero long 0 pfour long 4 mask long |<25 lll long 0 mask2 long |<24 parplus4 long 4 xx2 res 1 yy2 res 1 xx1 res 1 yy1 res 1 Mem res 1If I run a program to just collect one value from one pin at a time the magnitudes compare correctly with the above code and with the oscilloscope outputs.
you need to define parplus4 before the loop, every cycle you get an additional par added to it, so
loop1 parplus4= par + 4
loop2 parplus4=par+par+4
--Steve
Propeller Tools
