Question about Parallax GPS difference.
Hi
Only to know about the difference between
these two Parallax GPS:
PMB-248 GPS Receiver + Cable (Code 28500) = $39.99
, and ,
Parallax GPS Receiver Module (Code:28146) = $79.99
Thanks , Mark
, and ,
Thanks , Mark
The item code 28500 (the cheaper one) doesn't have any BS2 demo code at the Parallax web page and the more expensive
one has a BS2 demo code.
It seems that they could be very different since Parallax isn't using the same code
for both GPS.
Sorry about my questions but , I don't know enough about
the items.
Thanks Mark
Parallax isn't using the same code because the interfaces are very different. One is a prompt and reply type format (the expensive one), the other is a listen format (the cheap one). On the expensive one, if you pull the fourth pin low (the RAW pin) it acts exactly like the cheaper one.
