Has any one use this chip before DS32KHZN/DIP is a temperature-compensated cry
DS32kHz is a temperature-compensated crystal oscillator with an output frequency of 32.768kHz.
The Data Sheet show a few different way to hook this chip which one would be the best way to· use this chip
·http://datasheets.maxim-ic.com/en/ds/DS32kHz.pdf
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 8/19/2009 11:38:15 PM GMT
··Thanks for any·
Sam
Figure 6 shows one circuit that can be used to reduce the current consumption of a DS32kHz and an RTC.
This is the·one I used and it works very well
··Thanks for any·
Sam
However, the question in the title line has an answer that is nearly certain.
"Has any one [noparse][[/noparse]used]·this chip before?"· I'm sure the answer is Yes.
· -- Carl, nn5i@arrl.net
