Basic Stamp 2 for residential climate control via PC
I have an old basic stamp 2 kit which I would like to use for home climate control. While I have experience in control, I have forgotten everything I knew about the basic stamp. In banging the internet, I remain unsure if it is capable of reporting sensor readings to the pc. At the least, I need to get the data to the pc for analysis. Also of course, I will be using relays to control the heat, cool, and fan contacts for the thermostat.
I am finding documentation very sketchy. I have lost the documentation I received with the stamp.
If it is impractical to maintain bidirectional data between the stamp and the pc, are there suggestions for a different route? Money is definitely an object.
Thank you all
Derek
Thank you all
Derek
Jeff T.
Derek
Tia'Shar Manetheren
outside temp/humidity
inside temp/humidity
supply air temp/humidity
return air temp/humidity
evaporator temp
compressor current
fan current
current to the main breaker in the home
I intend to strategically operate the compressor at times of maximum efficiency, such as at night, to reduce indoor humidity and "store cool" using the thermal inertia inside the home. I will study the results of this to determine what steps to take after this test.
I would like to hear ideas regarding how to keep costs down on the sensors in particular, as I am trying for a low cost solution that is within the grasp of people with little money who are the most needy of reduced energy costs.
I would also like to hear ideas regarding the use of wireless sensors.
Regarding the current sensors, I would prefer current sensors that are easy to clip on to wiring in the breaker box and a/c unit.
Also, has anyone seen threads discussing this idea before? It seems it should be getting very popular nowadays with energy costs so high and the destruction of our environment being accelerated by our current means of energy production.
Derek
I wonder what the cost comparison would be between the hardware necessary to implement the x10 solution versus a wireless solution.
In case you did not know when you search the forums use this search engine http://search.parallax.com/
Jeff T.
Tia'Shar Manetheren
Tia'Shar Manetheren
Parallax 28018 Sensirion Module
Thread for my SHT11 module
My Module page with examples and code links
Tracy Allen's web page on usage of the SHT11 sensor
You could also look at pairing a DS1620 Digital temp sensor and the HS1101 Humidity Sensor to save costs. This humidity sensor can be setup with a 555 timer so you can just read the frequency output to guage humidity. The 555 timer circuit is on page 3 of the datasheet. The DS1620 is pretty straightforward.
You could easily place the HS1101 humidity sensor at each of your locations, then use one of the SHT11 sensors to "validate" the readings/values to increase the accuracy of your final setup. I did this for a stainless steel thermistor probe for my polar bear plunge datalogger. I could read the value with RCTime but had no idea how to convert that to a true resistance for the temperature. By comparing readings between the thermistor and the SHT11, I created a simple chart of values for the range I was looking for. Not perfectly accurate, but accomplished my goal.
Andrew Williams
WBA Consulting
Regarding cooling just one room, I bought the smallest window unit I could find, it only draws 8 amps. That is about half of what a space heater draws. To put the energy cost in perspective, a space heater uses about 1.5 kw. If you were to run a space heater 24/7, and your cost per kilowatt hour is around the average of 10 cents, then the space heater will cost you about $120 per month to run.
Conversely, if you ran the window unit like that your cost would be half that. Since the compressor doesn't run all the time, your cost is even less.
Regarding the store cool technology, that is a great idea I like as well. For this project though, I am thinking of using the thermal inertia inside the home because it is free, and if the solution is not very cheap, most people will never implement it.
Derek
Thanks for the info and links. I looked at the SHT11 on your website and it looks good, though I could not find pricing. I will let you know what I find when I finish investigating the links you sent me. My experience has been with industrial equipment which uses 0-5V, 4-20mA, or relay contacts for sensors. I guess I need to find a good tutorial on the basic stamp to see how it uses RC timing and clock to implement sensor readings.
Derek
