Pin Sharing Between Stamp Peripherals
·For a Controller/Datalogger project I am working on I have allotted the following Stamp I/O assignments:
·TLC2543 ADC -··cs, ·Sdo *, Sdi *, clk *
·DS1302 RTC - Data_I/O, Clock, Chip Select
·#27937 Memory Stick Datalogger - RTS, RXD, TXD, CTS#
·For a total allocation of 11 pins. I need to have 7 or 8 pins for control. And the Stamps I have are all the 16 I/O pin version. Hence· the··problem.· Per Tracy's write-up these [noparse][[/noparse]*] pins "can be shared with other serial peripherals". But with which other peripheral pin assignments ?
·If necessary I could use the following IC for control, but I would like to be able to use the "OutH" command for the control pins; and, if possible, I would like to have a few extra pins - as this is a work-in-progress:
·74HC595 shift register -··clk,·Data_in,·Latch
·Any suggestions in regard to pin sharing would be appreciated.
·By-the-way, can I use aliases for shared pin callout?
·cheers, David
pin y = TLC2543 Sdi, Memory Stick Datalogger RXD, 74HC595 data_in
pin z = TLC2543 clk, DS302 Clock, 74HC595 clk
pin a = TLC2543 cs
pin b = DS1302 Chip Select
pin c = 75HC595 Latch
pin d = Memory Stick Datalogger RTS
pin e = Memory Stick Datalogger CTS
Basically any DO/TX lines can be shared, any DI/RX lines can be shared, bi-directional DI/DO can be shared if you have a resistor on the output pin of the peripheral to prevent short when the line is being used as a DI elsewhere. Clocks can always be shared. Chip select (CS, enables, latches, etc) usually need their own pin (although I often use a "master" 74HC595 to control multiple cs/enable/latch lines on peripherals, but the cascading and programming gets a bit thorny).
I'm not familiar enough with the datalogger to be able to say if RTS and CTS can or can not be shared with other lines; if that is possible pin count could be cut by 1 or 2.
TLC2543 clk with DS1302 Clock
TLC2543 Sdi with DS1302 Data_I/O
You could also use a BS2p40 which has another 16 I/O pins (two banks of 16).
Many thanks for your replies. I am now confused on a much higher plain
to first try the design w/o using the -595. I also appreciate the alert on using the 10k
protection resistors.
The reason for not going to the 40 pin Stamp is that I have several regular Stamps
available and I knew that my pin allocation problem could be solved, if necessary, by
incorporating the -595.
Again, thanks, David
Not sure if this would work for your situation but what about decoders/demultiplexers such as the 74LS138. With this IC, you can take 3 i/o pins and make 8 output pins. Each binary value (from 000 to 111) selects one of eight outputs. You said that you need 7 or 8 pins for control. This might work. Check out the data sheet for these IC's. I use them whenever I don't have enough output pins. Good luck.
Bob
