Micro SD communication
Just wonder if anyone has ever try to conect an sd card, control by a propeller (demo board ,or else), on a pc using the usb port so that Windows explorer can see it, and also read or write it ?
Thanks for helping
Regards to all
N.R.
Thanks for helping
Regards to all
N.R.
The USB port used by the Propeller is not a general purpose USB port. It only can be used for a serial port and Windows Explorer has no way to see it. It might be possible to write an I/O driver for Windows that would pretend to be a networked disk drive to Windows, but would actually talk to the serial port and send commands over the serial port to the Propeller that would be interpreted by a Propeller program. You're talking about a lot of work done by someone expert in writing I/O drivers for Windows.
Much easier would be to use an existing program like Windows Kermit and write a Kermit client for the Propeller. There are already simple Kermit clients for the Propeller that could be "fancied up" to use newer versions of the SD card drivers that support subdirectories and FAT32.
It might be possible to program the Propeller to emulate a usb device in software, but that would not be for the inexperienced coder.· But for reference I would read through this project using an avr chip as it explains some of the data protocols involved.
Post Edited (Mike Green) : 8/18/2009 6:34:51 PM GMT
The full control of the communication as to be manage under Propeller system via a simple UI giving access to the SD locally or from the PC via the USB port. This was done with the bridge (plug and play) solution but, I just try to figure out if I could reduce the hardware bill going software.
Considering Mike's reply, I can conclude that the hardware is the simpless solution.
Thanks for helping
Regards to all
N.R.
Anyway, I'm surprised something similar to the AVR project above wouldn't be possible on the Prop with all of it's parallel processing power...· they are using a lowly Tiny2313 AVR running at 12Mhz for their usb in software solution, can't the Prop could do something like that?· What about all that 160MIPS?
Post Edited (Mike Green) : 8/19/2009 5:38:30 PM GMT
1. PC has a USB SD card reader plugged in.
2. Where the SD card should be in the reader it is not. Instead the SD interface is somehow connected to Prop pins.
3. The SD card is connected to some other Prop pins.
4. Prop just acts as a pass through.
Bingo you can program the SD with Prop as a "pass through", without having to fiddle around swapping those dinky micro SDs.
Now that wastes pins and may not work anyway. So why not sit the Prop on the SD to SD adapter lines. Arrange that when plugged to a PCs USB the Prop is passive. When not plugged to the PC the prop can use the SD.
So now I can build a USB Prop gadget that I can plug to my PC for reloading, reconfiguring etc without swapping cards around.
That's not such a daft idea is it ?
How do we get the Prop to go passive when the USB SD interface is active ?
As for the AVR project, I have incorporated it in several projects.· Granted it is low speed, but one of the benefits is that it is a direct usb device that windows recognizes.· You are not limited to HID classes, it can perform digital IO and ADC/DAC.
It's based or at least inspired by the AVR USB project if I remember correctly.
I had a play with avr-usb a long while back, it's pretty neat I must say.
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
You won't find it in the object exchange. I wrote it and I plan to dual license the code under the GPL and a more restrictive commercial license. The OBEX is only for MIT licensed code.
You will find it attached to a post in the forums though. I use it to simulate a CDC-ACM compliant serial port here, but you can pretty much do with it what you want. It's far more standards compliant than the AVR stack as we have more processing horsepower to play with.
One day (when I get some time) I'll get it cleaned up and posted on a web page somewhere.
lt's not particularly silly, is it?
To make things clear:
The sd card is actually enclose in a unit control by a propeller chip.
There is a 4x4 keyboard on the unit alowing the user to manage the files on the local(unit) sd.
One key of the unit keyboard tranfer the full control of the sd to Windows explorer.
In other words, the sd card in the propeller unit act then as if it was a usb BOM FLASH DISK plug on the PC.
I hope i have made the idea clear
(sorry for my english)
Thanks again
regards to all from UNTEL
