download source code to go with Robotics with BoeBot ??? — Parallax Forums
mikedivmikediv Posts: 825
edited 2009-08-28 17:49 in Robotics
Guys I can not seem to find the software to go along with the Robotics for BoeBot kit,, I don't mind typing in most of the examples but some of the stuff is really long is there a place where I can download
the source code for all these examples???
    edited 2009-08-18 17:42
    You can easily cut and paste from the downloadable PDF form of the text. I don't think there's a compendium of the source code outside of the manual. I vaguely recall some comment about deliberately not making that available because of the educational use of the BoeBot and concern about cheating although it's so easy to cut and paste that I don't think it would matter if there was a ZIP file available.
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-08-19 02:28
    This may help:
    http://isl.ecst.csuchico.edu/DOCS/Robots/Parallax/BoeBot/Code/Robotics!/
    and if you ever want to upgrade to java language, there is an updated
    JBot manual, inclusive code.
    http://forums.parallax.com/showthread.php?p=829542
    regards peter
    Post Edited (Peter Verkaik) : 8/19/2009 2:33:52 AM GMT
  • WhitWhit Posts: 4,191
    I think you learn a lot by typing it in youself. Not only do you kind of absorb the logic, but you learn how to find errors and look at the code carefully.
    But as Mike said, there is alway cut and paste.
    Whit+
