trouble with 6.25 crystal? — Parallax Forums
ksamksam Posts: 19
edited 2009-08-18 13:36 in Propeller 1
I'm working on a little project trying to make a small video game. I'm using the game Planetary defense from Michael Park:
http://forums.parallax.com/showthread.php?p=770719
I'm trying out the 6.25 crystal instead of the 5 Mhz one.· I've changed the xinfreq to 6_250_000, but this doesn't work.· It works fine with the other crystal?· Any suggestions?
  • RaymanRayman Posts: 16,058
    edited 2009-08-18 12:45
    If by "doesn't work", you mean you don't get video out... You may need to tweak the video drivers for the higher clock freq...
    Rayman is right - you have to change _xinfreq not only in your top-level object, but in every object it includes.
    Worse, some of the drivers build in hidden assumptions about 5MHz (video drivers are worst at this). Look for lines like:
                            movi    frqa,#(pr / 5) << 3     'set pixel rate
                            movi    ctra,#%00001_101        'enable PLL in ctra (VCO runs at 4x)
    See that (pr / 5)?
    That assumes 5MHz.
    Replace that with
                            movi    frqa,#((pr*1000) / 6250) << 3     'set pixel rate
    Best,
    Bill
    ksam said...
    I'm working on a little project trying to make a small video game. I'm using the game Planetary defense from Michael Park:[noparse][[/noparse]color=#0000ff]
    I'm trying out the 6.25 crystal instead of the 5 Mhz one. I've changed the xinfreq to 6_250_000, but this doesn't work. It works fine with the other crystal? Any suggestions?
    [noparse][[/noparse]/color]
    Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
    www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
