current sensing using soic chip
I am trying to read the charge- discharge rate of a battery. I have found the SENSOR CURRENT 20A 5V BI 8-SOIC at digikey. The question is connecting the chip. I don't see how you connect one of these to the battery. A 20amp current requires a large wire. Am I missing something here?
· Do I run all the current thru this chip?
· I see something called a toroid sensor with built in amp, but cannot find a part number anywhere. Any ideas?
Thanx
Don
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Post Edited (mosquito56) : 8/17/2009 3:26:13 PM GMT
Thanx
Don
There are also current sensors chips that measure the voltage drop across a shunt resistor.
Rich H
Thanx
Rich H
