Enjoy! Fixed-width decimal printout, with decimals
localroger
You might have noticed that most of the public output objects have nice fixed width binary and hex outputs but the decimal output is variable-width so you can't use it to create nice formatted displays.
*cough*
You can consider this public domain, as there isn't enough here to justify a copyright claim.
Post Edited (localroger) : 8/17/2009 4:55:05 PM GMT
*cough*
PUB fdec(value, len, dp) | p, fnumbuf[noparse][[/noparse] 4 ]
Print a formatted signed decimal number
The dec method provided with most output objects inexplicably
doesn't do fixed length. This version also inserts an
optional decimal point. A negative dp specifies dead zeroes,
e.g. dp=-3 returns 000 instead of 0.
Observe the sneakiness with which I allocate a temporary
string buffer... fnumbuf thinks it's 4 longs but I use
it as bytes so I can write the decimal out backward.
Note that you can't return a pointer to this string since
it's on the stack and goes away when we return; to do that
you must create a buffer outside of this routine and add
its location to the parameter list.
First we prep the buffer with any leading zero and
decimals that might be called for, then write the number
down backward skipping over the decimal and skipping
over any remaining zeroes for the minus sign.
bytefill(@fnumbuf," ",14)
byte[noparse][[/noparse]@fnumbuf+14] := 0
p := @fnumbuf + 13
if dp > 0
repeat dp
byte[noparse][[/noparse]p] := "0"
p--
byte[noparse][[/noparse]p] := "."
p--
p--
elseif dp < 0
repeat -dp
p--
else
p--
rdec(value, @fnumbuf+13)
str(@fnumbuf + 14 - len)
PRI rdec(value, atloc) | s
This is works like dec but writes the number to memory
down from the starting atloc. It will not write over
a decimal point; the string should be pre-loaded with
any necessary leading zeroes and decimals. There are
no controls so be sure the buffer is large enough to
handle a signed, decimalled 9-digit number.
s := 0
if value < 0
-value
s := "-"
repeat while value <> 0
'skip over decimal
if byte[noparse][[/noparse]atloc] == "."
atloc --
byte[noparse][[/noparse]atloc] := value // 10 + "0"
atloc --
value /= 10
if s
'skip over any non space before writing sign
repeat while byte[noparse][[/noparse]atloc] <> " "
atloc --
byte[noparse][[/noparse]atloc] := s
