Applied Sensors - Thermometer Calibration Page 78, question?
Hi all, after ran ThermometerCalibration.bs2 I obtained the following values: kal = 15608, degC = 26, rct = 522 and Kelvin = 299 (273+26). kal = (299·* 522) / 10 = 156078 / 10 = 15608, all is OK, but I can see in the memory map at the top the 2 bytes stored, C4 and 3B. C4=196, 3B=59 and C43B = 50235, where is the relation with the constant calculated? If I recalibrate and obtain an other value of kal 15556 for example C43B remains in memory! Curious, is it not?
point 2: When you run the calibration program, it uses the DS1620 temperature sensor as a calibration reference. I finds a new value for Ekal and enters that in the same eeprom locations where there was originally the $3BC4 = 15300. In your setup, that changed the value stored there to 15608. That happens at RUN time, and does not show up on the memory map. The memory map only shows the memory as it is in the program code at compile time. To make it show up in the memory map, you coulc change the statement in the program to:
That would then become the default value, until you again hold down the button for three seconds to enter the calibrate subroutine.
Tracy Allen
www.emesystems.com
