Servo port 12 stopped working...
What could cause one of my servo ports to stop working? I have checked the servo, its fine.
Using BasicStamp2 + BOE
Any help would be welcome.
Henry.
Henry.
Try making a connection between the servo plug and the breadboard area on your BOE with jumper wires inserted into the servo plug and the other end into appropriate power and I/O pin sockets around the breadboard.
I am using a 7.2v power supply (6 AA NimH), with the servo jumper set to Vin.
[noparse]:([/noparse] think I may have fried it.
I was under the impression that the servo's could handle upto 7.5v and that the BOE regulated power to 5v for the breadboard. This is a BOE Bot and port 12 is the main drive right servo.
I will test, but is it possible this has damaged the BS2 chip itself, or just the board?
Just using a 7.2V supply and running the servos off that (as Vin) shouldn't cause problems.
I think thats the BS2 chip fried then.
What I really need, is to find out how this happened, so I don't blow any more chips in the future.
Why pin 12? Its only ever had a Parallax Servo connected.
Hmmm, forgot I had Vservo going to the breadboard for an extra servo, but it was connected to pin 11.
Still don't know how this happened. I am reluctant to continue my development project untill I know exactly what occured.
How can I use Vservo to power another servo, without using the servo ports (ie, directly connected to breadboard)??
Post Edited (henry151) : 8/15/2009 11:29:42 PM GMT
