EEPROM confusion
In the Propeller Demo Board Rev D/E/F Schematic (1), the EEPROM is shown as a 25LC256-I/ST. It has a two-wire serial interface and three address lines. This is confirmed by the propeller manual (2).
When I looked for the pin-out on Microchip's website (3), however, the 25LC256-I/ST described there has a three-wire serial interface with hold and chip select lines but no address lines.
I want to build my first propeller project and need the external EEPROM but don't now know which chip to use.
I've searched this forum for 25LC256 but found no matching posts. I've googled "parallax propeller 25lc256" and read every result that I can translate but didn't find
anything helpful.
Can anyone tell me why the two chips with the same number seem to differ so considerably and which chip I should use with the Propeller?
Thanks in advance,
fish
References:
1. www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropDemoDschem.pdf
2. www.parallax.com/Portals/0/Downloads/docs/prod/prop/WebPM-v1.1.pdf
3. ww1.microchip.com/downloads/en/DeviceDoc/21822F.pdf
anything helpful.
Thanks in advance,
fish
References:
From the Parallax Store:
www.parallax.com/Store/Microcontrollers/PropellerComponents/tabid/785/CategoryID/87/List/0/Level/a/ProductID/400/Default.aspx?SortField=ProductName%2cProductName
32K-byte EEPROM Datasheet (.pdf)
http://www.parallax.com/Portals/0/Downloads/docs/prod/oem/24LC256.pdf
32K-byte EEPROM Schematic (.pdf)
www.parallax.com/Portals/0/Downloads/docs/prod/oem/24LC256schem.pdf
Post Edited (Bob Lawrence (VE1RLL)) : 8/14/2009 7:34:27 PM GMT
f
Post Edited (Bob Lawrence (VE1RLL)) : 8/15/2009 12:17:06 AM GMT
