Broken PropMod!!!
My propmod is broken...· I'm using my adjustable power supply + a multimeter, and whenever I adjust it so the input it above 1.8 volts, the power section of the propmodule gets incredibly hot!· Has anyone had the same problem?· Also, does anyone know how to fix it??
Help!
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
Help!
It's not like you can pull out a jumper wire to isolate different parts of the module to try to locate the problem. How do you think you broke it?
PG
PG
Oh, I don't really have a circuit, as it is on a breadboard... As it happens, I was testing it with a simple program to check if it worked, which just flashed an LED...
PG
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
If it's not Parallax then don't even bother.
I have changed my avatar so that I will no longer be confused with others who use generic avatars (and I'm more of a Prop head then a BS2 nut, anyway)
PG
I was tempted to ask you how clean the power supply is - but since it's one of *yours* [noparse]:)[/noparse]) it's OK, right?
You know that heat on a supply can also indicate too much A.C. ripple on the input D.C. making the regulator work harder.
Just crossing the 't's and dotting the 'i's...
- Howard
[noparse][[/noparse]EDIT - oh sorry, I didn't see Microcontroller's report - looks like a board flaw?]
Still, that's one of the main points that makes the propmod so awesome... An on-board boost converter...
Thanks.
PS: Microcontrolled, try using a 3.3v regulator and having the Vout connected to 3.3v on the module...
PG
There's no mystery at all. The PropMod is sucking up all the spare electrons lurking in the Demo Board, so there are no extra electrons to jump up and down and make a glow from the speed of their jumping. You need to plug the hole in the hose from the PropMod.
PG
PG
Brandon C.
No purchase necessary. See back panel for more details.
Tired of the same old robot brains? not enough processing power? Get the Propeller Robot Module now!!
It is a 700mA wall wart from Parallax, that should be good enough. The thing is that it doesn't find the PropMod when a scan is run.
Post Edited (microcontrolled) : 8/15/2009 12:52:27 PM GMT
Can you turn on the PropMod by itself?
Brandon C.
PG
