How to assign only 3 of 4 pins for OUTC to a variable....
Here is what I'm doing, and it works fine....
thumbselect VAR OUTC 'includes I/O 8, 9, 10, and 11 as output pins. 11 is for an edge or face state, 8, 9, and 10 decode which thumbwheel to read
FOR idx = 0 TO 7
thumbselect = idx 'Assigns idx value to Nib OUTC thus setting up which thumbwheel to read
Digit(idx) = INB 'Stores the current value of the thumbwheel at Digit(idx) and will fill the Digit array with the starting values of all thumbwheels
NEXT
What I'd like to do instead is assign only I/O pins 8, 9, and 10 to thumbselect....leaving I/0 pin 11 available for other use.
I was trying to use pin 11 for something else, forgetting that it is periodically forced low by the above FOR NEXT loop. I'm out of pins and can't move to a larger Stamp. Any thoughts or suggestions received with gratitude.
Thanks.
FOR idx = 0 TO 7
NEXT
Thanks.
If you need I/O 11 as an output, this scheme won't work. You'll have to assign values individually to OUT8, OUT9, and OUT10. This might look like:
OUT8 = idx.bit0
OUT9 = idx.bit1
OUT10 = idx.bit2
Another idea, if bit11 is a bit variable used for I/O 11, you could do:
OUTC = (bit11<<3) + idx
This always keeps I/O 11 current when you change I/O 8-11
Works perfectly.
