newbie questions on FemtoBasic
Interplanetarian
I've got FemtoBasic running on a USB Prop and I'm typing test pgms in via the Parallax Serial Terminal.
1) I'm using basic to get aquainted with the Prop but I lose the program after ever power cycle. Is there a way to download a basic text file from my PC so that I can edit externally and then retry?
2) Can basic write to a VGA screen that I've got plugged into the Prop? VGA_Demo.spin works fine.
You could attach an SD card to your Prop and store (and load) PC-compatible text files from the SD card also using the SAVE and LOAD commands. The FemtoBasic documentation describes what SD card pins go where. SparkFun has a nice little SD card socket that can be used with some jumper wires on a Prop Demo Board to do this.
2) FemtoBasic comes in two versions (in the same archive), one for use with a TV and one for use with a VGA display. It's just a matter of changing a couple of lines of code at the beginning and recompiling. That's been done for you and all the various binary versions are provided pre-compiled. Just use the Propeller Tool to load the VGA version.
FemtoBasic is the stand-alone version made for use with a PS/2 keyboard and either a TV or VGA display. If you're using PST, you're probably using BoeBotBasic or DongleBasic which are versions that use the programming connection to your PC as the "console". If you're using one of those, you can use a different terminal emulator that has the ability to either capture the displayed text to a file or "type" the contents of a file as if it came from a keyboard. This could be used so you could edit programs using a PC editor. That works, but you have to have a terminal emulator that does this.
Post Edited (Mike Green) : 8/13/2009 3:41:34 PM GMT
Thanks for the quick response.
I missed the SAVE to local EEPROM - I had been thinking it only applied to the SD drive (which I don't have).
The FemtoBasic I was running was version 2.004. After your hints I went to the object exchange and got 3.007.
Works like a champ - VGA and kbd came right up.
Dave
