Question regarding use of monitor with BNC input on Prop.
Got a couple monitors dropped off at my office tonight.
Two of them have both the standard "vga" connector, as well as 5 BNC connections.
R,G,B,HS.VS.
I've found cables which attach to these to connect to a VGA card.
Is there a chance I could feed a composite signal, maybe splitting the I/O lines
into R,G,B, and managing SYNC somehow, or am I dreaming here?
OBC
New to the Propeller?
R,G,B,HS.VS.
OBC
You can however pay $100 dollars to buy a device that will do that for you.
Nyamekye,
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Now, going from a composite (i.e. NTSC) signal to component (i.e. RGB+S) is a whole 'nother kettle of fish.· There are black boxes which do it (often not very well), but the bigger problem is the composite signal typically has sync frequencies to slow for a typical monitor.· Thus the black box is even more expensive 'cause it has to upconvert the signal.
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
If they are really top range and universal units then one of the sync inpits could be a combined one ie RGBS using 4 wires. Syncs on green would use composite levels ( 0.3 v ) under the green. Menu options may show this. Some medical grade units take almost every sort of input
Then there is the RGB or YUV options. Y is the total luninance signal of 0.7 V with 0.3 V syncs along with the colour difference signals. If you bet locked pics but they are very green or very magenta then its probably the wrong flavour.
Style and grace : Nil point
I need to find a monitor that support both VGA input as well as composite/S-Video.
Thanks for the answers guys. Even if they weren't what I wanted to hear.
OBC
