PropMod is not working — Parallax Forums
MicrocontrolledMicrocontrolled Posts: 2,461
edited 2009-08-13 14:06 in Propeller 1
I have recieved a PropMod from mctrivia and it worked properly. That is, until I hooked it up to a Boe Bot body and had it run servos. It worked for a while then, until I accidentally plugged in a wall wart without taking the battery off first! I had it protected by a 5-volt regulator but somehow it still got damaged somehow. Although I did do this, I believe the trouble with it started BEFORE I did that and somehow my PropMod just broke for no reason. Now when you plug it in with all the proper regulated connections and everything it STILL doesn't work and the power light goes out until you unplug it. I assume that it is shorted somewhere to cause this but could anyone tell me WHERE so that I can attemp to fix it?
Thanks in advance!
-- Micro
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
If it's not Parallax then don't even bother.
I have changed my avatar so that I will no longer be confused with others who use genaric avatars.
  • RsadeikaRsadeika Posts: 3,862
    edited 2009-08-13 00:07
    Does the company have a warranty program? Most reputable companies have one, so just send the unit back, and have it replaced. I would not try to fix it yourself, will void the warranty for sure.
    Ray
    edited 2009-08-13 01:07
    It is sold by mctrivia, a common forum member, on his site PropMod.com. I believe that he runs the whole thing from his garage. The thing of the matter is, he gave it to me for free. He gave away 5 free PropMods to anyone under 18 under the condition that they would use them in a Gadget Gangster project. I was about to impliment it in a gadget gangster project when this happened, and here I am.
    edited 2009-08-13 02:14
    Send him a private message explaining what happened. He's a nice person.
  • VaatiVaati Posts: 712
    I sorta had the same problem... The power supply section starts heating up a bunch and since it draws power from the usb, it doesn't really work...
    Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
    *-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
