Need help with Schmartboard connection
I have a Parallax·schmartboard·with a·Parallax usb prop plug connected to it.· It works perfect and I am able to connect to it via the Parallax Propeller tool software.
I also have a Freescale mc56f8006vlc dsc/microcontroller.· I need to interface the schmartboard with the mc56f8006vlc.· The freescale chip is on a badge used for a security conference.
Here is what I know.· There are labels on the badge to identify some of the Freescale pins, I know that I need to connect to the TX, RX and GND·pins, which are labeled.·What I don't know is can I just use the Parallax USB tap and connect it directly to the·TX, RX, and GND·freescale pins, or do I need to wire the Parallax·schmartboard·to the freescale chip.··To program the·freescale chip I have the Codewarrior software installed, so I just need to figure out how to connect to it. I am having a lot of trouble finding information.· Just for clarification, this isn't the Freescale demo board, it's just the single chip (mc56f8006vlc) used in a circuit board worn as a badge.· Any help is much appreciated.
I have tried the method you mention and I can't connect.· I know the Parallax USB prop plug works because I can access the schmartboard with it.· I know the badge works because it lights up as expected. So it must either be·the way I have it connected or the Codewarrior software (I'm not too familiar with Codewarrior, but it seems all of the funtions to read from the Freescale are greyed out).· Can you tell me how to do a definite test once connected to the Freescale chip?· Can I just open up Hyperterminal in Windows XP and get some kind of feedback from the Freescale chip?
re: Can I just open up Hyperterminal in Windows XP and get some kind of feedback from the Freescale chip?
This would depend on what the Freescale software does. If it is written to respond to serial input you should see something. Is it possible the security is set on the freescale chip so the software can not be copied?
http://www.wired.com/threatlevel/2009/07/defcon-badge/
how about "hacking" off the freescale-chip replacing it by a propeller
demonstrating what a propeller can do ?
best regards
Stefan
Here is a link to the Defcon customized Parallax schmartboard if anyone is interested.
http://blog.schmartboard.com/blogschmartboard/2009/07/defcon-17.html
I am afraid I don't have the freescale expertise to help in hacking a system that was most likely designed to be difficult for the unauthorized masses to hack.
Good Luck,
Kurt
