Help with connecting XBee to BS2
I've bought a XBee Explorer Regulated board (http://www.sparkfun.com/commerce/product_info.php?products_id=9132) & a XBee Explorer USB board (http://www.sparkfun.com/commerce/product_info.php?products_id=8687), intended to be connected for a BS2sx & a PC, respectively.
I'm not sure if I've the right board as most posts I've come across uses a AppBee board. Are these boards usable?
Also, regarding the connections, is it possible to connect the board to pin 0-4 or any of the I/Os of the BS2?
can connect them directly, though it's possible that you'll need a 10K resistor.
The XBee Explorer board is for connecting an XBee through a USB port to your PC, not for connecting an XBee to a Stamp. I believe you knew that already, right? It should give you a perfectly good "base station", as it were.
You bought the right boards.
Can i use the regulated 5V from the BS2 to power the board?
regarding the base station. what interface can be used to send out the signals? I've read that it's possible to use the hyperterminal in XP, is there any similar interface for vista as well?
I don't see where the SparkFun board does anything for the logic signals regarding 5V signal levels. It may be that the xBee modules have 5V tolerant I/Os, but I'm not sure. silvie369 is correct that you can often just put a series resistor between the BS2 I/O pins and a 3.3V device's I/O pins. The AppMod adapters made by Selmaware used a buffer designed for this logic level conversion (www.selmaware.com).
Re. the SparkFun board's ability to work with 5V signals, I have to admit I'm just assuming it's okay, based on the product description:
"Description: The XBee Explorer Regulated takes care of the 3.3V regulation, signal conditioning, and basic activity indicators (Power, RSSI and DIN/DOUT activity LEDs). It translates the 5V signals to 3.3V so that you can connect a 5V (down to 3.3V) system to any XBee module."
However, Mike is certainly more knowledgable about this than I am. In addition, on double-checking, I see that among the comments on the Sparkfun product page is this one:
"@Valen - I question this too, as there's no level shifter shown in the schematic. Digi says (but not in the manual from what I've seen :-() that the I/O pins are *NOT* 5V tolerant, so I don't understand how/why they can say that above, at all. "
I wonder (Mike?) if there's a way to know if using a 10K resistor in series between the Stamp I/O pin and the pin on the XBee Regulated board will protect the XBee properly.
As an alternative, there are boards at adafruit.com that have a buffer built in. I also understand that Martin Hebel intends to make more of the currently out-of-stock AppBee-SIP boards, which I've been using regularly with Stamps. IMHO, they're the best option.
