twisted pair vs. data cable
Hi, I'm putting my Propeller and my IGBT drive board/DC buss in separate adjacent enclosures. The data wires from the Propeller to the drive box can be twisted pair as suggested by some of my chip suppliers but I also have some shielded data cable that has a static wire in it and an aluminum foil shield inside the outer teflon jacket. I've been told that you only ground one end of the static line to avoid making an AM antenna. Both my opto-isolators and my hall-effect current sensors give me isloation but I want to avoid having noise reflected back to the Propeller. Should I consider installing ferrite beads over my wires or should I just step up to coax for each line?
If the shield were to be grounded at both ends then there is the possibility of an "earth/ground" loop being set up. This happens because there is a difference in "earth" potentials, beleive me there can be huge differences over just a few feet. This would set up currents on the shield which could then induce ino the signal ccts. Again ballanced feed reduces this.
As to the antenna being formed, this will very much dependant on how hostite the surrounding enviroment is. If you are installing it on the tail end of a high power transmitter then caps, coils and ferrite collers will be required. Even the if the cabe lenth equates to 1/4 wavelenth (or multiples) then it will be a fight ( We had a 100 Watt lamp connected to the outer cassings, of the two halves of a 200KHz transmitter, if it was bright then both halves were running OK).
Keep the interconnection short and low imedance.
Style and grace : Nil point
