FTDI serial driver sloppy?
Kye
I just wanted to ask if anyone else who has developed a serial driver has had this problem.
For some odd reason in any terminal program I use on windows using the FTDI virtual serial port I can't transmit back to back serial bytes.
Back to back as in:
SBBBBBBBBSSBBBBBBBBS
Where S is the start·or stop bit and B is·a data bit.
I asking because I have to insert extra stop bits to fix the problem. This is even with the number of stop bits set to 1 in the FTDI·driver.
... The problem just seems odd, and is getting in the way of 100% optimization on my next version of my·serial driver.
Nyamekye,
Back to back as in:
Nyamekye,
Could your routine be off somehow, perhaps transmitting one less stop bit than you think?
The receiving mechanism in the FTDI chip doesn't really care how many stop bits it receives as long as it's at least one.
I have to actually add in an extra pre startbit stopbit to make sure windos doesn't receive corrupted data.
Best I can get is 11 bits per packet and not 10.
But the weird thing is that if I write the rountines in spin it doesn't matter at all and I can leave out the extra wait. Maybe the low speed makes the difference.
Thanks, for replying Mike.
Nyamekye,
Jonathan
lonesock
Piranha are people too.
I can get arround ~300000 bps.
Nyamekye,
You've got to remember in its original incarnation, the reason for the two stop bits setting was to give mechanical parts time to settle after striking a character at 110 baud
A stop bit doesn't need to be an integral number of bit times. It can be any fractional value > 1. Try using, say, 1.125 stop bits. Your baudrate may just be on the hairy edge of being too fast, so you could also try slowing your Propeller's baudrate by a fraction. For example if it's 9600, try slowing it to 9550.
My setup uses serial straight into the PC with no USB involved, so that removes one possible source of problems.
PhiPi's suggestion of tweaking the baud rate - yes, great idea, and I'll try that when I get home.
Also, I'm going to try talking to another working CP/M board (rather than to a PC), just in case the PC is taking characters that are typed on a terminal program and bundling them up with no gaps between them.
My problem may or may not be related to this thread. But if the gap between two stop bits were too short it could explain the problems I'm seeing. It probably is time to get out the scope!
Addit: reading the waveforms about half way down this page: www.beyondlogic.org/serial/serial1.htm#40 This is 10 bits (not 11, intriguingly), and there is an interesting comment there about the status immediately after a stop bit - if it is low then this is the start of the next byte. No gap at all. I didn't know that. There is also mention of framing errors - I wonder if one was writing a uart emulation, whether it would be possible to code for all the errors you can get - eg parity error, framing error. I'm thinking back to my first computer in the early 80s where you had serial to parallel converters built with discrete chips and leds that lit for various errors like this. It did make debugging easier.
Kye - I'll be following this thread with great interest.
Post Edited (Dr_Acula (James Moxham)) : 8/12/2009 1:15:10 AM GMT
This thread should die.
But, have fun using my next serial driver release - this will be the final version (if it doesn't have problems)·and it pretty much is perfect.
Nyamekye,
No, no no!! [noparse]:)[/noparse] This thread should live on in perpetuity. Because, at the bottom of your last post is some lovely shiny new uart code that I just can't wait to get home and try! Thanks++
Addit - all working, this object is brilliant and has enabled the zicog/triblade to not only get wordstar working but also games and even xmodem file transfers. Worthy of a seperate Post of Thanks!
Post Edited (Dr_Acula) : 8/12/2009 9:35:57 AM GMT
