Powering Propeller and Motor on the same lines
I was wondering, is it possible to power a Propeller and a motor on the same lines / buss?· I am thinking about something like putting a Propeller inside of a model locomotive.· This would result in all power coming from the two·rails but would need to power both the Propeller and the motor inside of the locomotive.· I understand that the power to the Propeller would need to be regulated to 3.3V, etc.· I know that this is basically·how DCC works for those of you familar with model railroading.· Would this setup work, or is it not recommended?· I don't have enough of a electronics background to answer this myself.· Also, what would be recommended for driving the motor.· I believe they are lower voltage.· Maybe 10-15V.· I was thinking of something like a H-bridge to get forward and reverse, etc.
Rob W.
Rob W.
PG
edit: thats a bad pic. let me get a better one
PG
PG
PG
In term of h-bridge depends on the voltage/current - I have used l293d, l298, tb6612 and mc33887. l293d is good cheap and simple for low power upto ~1a per motor also handles 2 motors. the l298 is also cheap and handles 2 motors, needs external protection diodes and upto 2A per motor. tb6612 is good for low power < 1.2A and does 2 motors, MC33887 is good for 5a but only 1 motor and needs a touch more to interface to prop (2 resisters per io pin). The tb6612 has a max voltage of 15V but all the others will do 10-15V without problem.
PG
In terms of caps, a cap across the motor leads as close to the motor as possible. and if possible a cap from each motor lead to the motor case (if its metal). The 2nd only work for some of the larger motors and if you have a big soldering iron, I dont normally bother and haven't had many problems.
The other thing to do is twist the motor leads together from the motor to the motor controller.
Style and grace : Nil point
Rail 1 - power for motor
Rail 2 - power for Propeller
Rail 3 - Propeller signal
Rail 4 - ground for motor and Propeller
I don't expect any sudden motor rotation changes.· The locomotive would run similar to a subway or transit system.· Pull into the station, pause, leave the station, etc.
-Thanks
