wire up to car
okay finally finished the code for my solenoid controller but now i just need to wire up to the car
okay what would i do to wire it up to power off of the car and what transistor would i use to use the output of the board to control 12vdc solenoid
i will put up the pull of it in a lil
For powering a Stamp off the car's electrical system, consider using a 9V regulator like the LM7809. The datasheet for the regulator (search the web for it) shows some typical hookups and recommended filter capacitor values. On the input side, you'll need something with a 25V rating. On the output side, a 15V or 16V rating will do. Use a fuse on the input side and a diode (like a 1N4001) to protect against an accidentally reversed battery. The 9V output of the regulator would go to the Stamp's regulator.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
and how would i connect this to the solenoids with my bs2
right now i have pin 6,8 to two resistors to two leds (simulating the solenoids) to the vss part of the board so is vss ground or what and if i had this wired in the car how would i need to connect the stuff
thanks
· -- Carl, nn5i@arrl.net
