Damaged Prop Plug? - Resolved
Whit
Hey All,
Has anyone ever damaged a Prop Plug? I hooked mine up the last night·(don't·really know if it is the one I had been using or a new one I just bought)·and got a "No Propeller found" message, after it searched.·I have two and tried the other and it worked.
How could I have damaged the Prop Plug? (I haven't tried a different USB cable - now that I think about it either)·I can't recall doing anything that might have damaged it.
Any other way to test it? Or should I just call tech support?
Any suggestions?
Whit+
Post Edited (Whit) : 8/9/2009 5:06:48 PM GMT
Any suggestions?
Whit+
PG
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
I have changed my avatar so that I will no longer be confused with others who use genaric avatars.
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap·shipping unless specified!··········150 left!!··
I checked it out completly just a few minutes ago. The USB cable is good. I can make connection with my other Prop Plug.
On the bad one, the lights do light, but it never connects correctly. It just keeps looking on different ports and never finds the Prop. Thanks for helping me make sure I wasn't missing something.
I will contact tech support Monday.
Whit+
I still stand in wonder that the act of baking an assembly, produces such a reliable result. If there is a problem then always look at the bit that is waggled, on connect/disconnect (or within 1/2 inch of it, or on a cable, 3 inches of it).
The 19" lcd that I am looking at at the present, had broken joints. The 17" at it's side had broken joints. How I love "recycling".
Get some flux on the plugs and gently sweat down the individual pins with a small tipped iron. Saves ordering the new one, hopefully, and saves that awful waiting.
Style and grace : Nil point
Post Edited (Toby Seckshund) : 8/9/2009 9:33:02 PM GMT
Thanks Dave!
Whit+
Just call me micro.
