AC One-shot/Timer?
I have a couple projects that could use 110VAC power for a specified amount of time after being triggered; like a one-shot/monostable multivibrator. Does anyone know of a non-electromechanical way of achieving such a thing? I entertained the idea of using a low RPM synchronous motor with a cam and switch, but I've determined that's not going to work for at least one of my projects. I'm also trying to minimize the part count and cost, so I'm trying really hard to avoid any DC conversion (well, I just don't want any bulky transformers. I'm open to half-wave rectification.). Am I asking the impossible?
-Paul
-Paul
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
If you want something very straightforward, use a SSR with a BS1 as the controller and a little 5V wall-wart to power it. There are lots of 5V wall-warts on the market now for powering USB-based devices.
-Paul
A second cheap method would be to search for a Seimens "LOGO" programmable relay on e-bay, etc. No programming software required, available in relay outputs, operates on 120 - 240 VAC and probably available for $20 or less.
Cheers,
Tom Sisk
http://www.siskconsult.com
