HSS Player (Mini-Me Version) now leaves 20k
Oldbitcollector (Jeff)
Thanks to the S3M-2-HSS converter, I've been driving people crazy with tracker mods.
I like Andrew's HSSPLAYER, but I wanted more memory to load larger .HMUS files.
So I've scrapped every bit of memory I thought I could loose from the player and it's objects.
(In otherwords don't use it's objects for other toys, they are very broken:
Things like extra keyboard PUB routines and SD write routines have been deleted!)
So here it is... HSSPLAYER (mini-me) which leaves 19K open for .HMUS files while
still allowing them to be read from the SD. Every OUNCE of memory is consumed!
Let me know how the color scheme works. The big screen (projection TV) I'm using is very off)
Added: Aurora.hmu which uses the 19k space.
Now that's what I'm talking about.. [noparse]:)[/noparse]
Added: Spent some time jumping up and down on the source code: Grab the 12k version
Resulting in an additional version which leaves 20k for .HMUS files.
Added: Axelf.hmu Requires 20k verison of Minime player
OBC
New to the Propeller?
Post Edited (Oldbitcollector) : 8/9/2009 2:52:30 PM GMT
OBC
I purchased a SB16ASP specifically so i could rock out with some mods on my dos box.
Ahh, the good ol days of mods, bbs's, 14.4kbps, and v.42bis...
You remember the "demo" scene? those demos used mods mostly....
here we are running the same demos that required a 386 running at 50mhz, on a little chip..
I love the prop... can't wait to see what parallax has in store for us in the future as far as chips....
And wheres that prop o-scope i need an o-scope....
Back in the late 80's I built an LPT port DAC so I could listen to mods...
(Didn't have a sound card!)
OBC
Attached to the top thread is a *very* hacked down version which leaves 20K free
and maintains all the functionality. It came down to removing characters to open the space needed.
OBC
You'll need the 12k version of the player.
OBC
