BS2SX, XBee PRO XSC, AT Command set, Errors?
xanatos
Hoping the XBee Xperts on here might shed some light on what I am seeing.· I am verifying the AT command set with the XBee PRO XSC, and I am using the X-CTU application now to test, rather than the BS2s.· The XBee's respond properly to many of the AT Commands, but reply with ERROR on many other - critial - commands.· A few notable examples:
ATCT, DB, ID, RE, RN, RO, RP, SH, SL, ST and VR all respond properly with either an OK or the current value set for that command.· The following all yield ERROR when the command is issued:· ATDH, DL, GT, MY, ND, PO, SP.
The most important item for my application, ATND, is what I need running most.· At the very least I want to be sure that ATND *IS* a valid command for the Series 1 PRO XSCs.... and then to determine why it errors on that command.
Thanks very much for your assistance, it is, as always, truly appreciated.
Dave X
Dave X
You probably knew that already. I don't have an XSC here to test. ·However, looking at Digi's manual for the XSC, I don't see the commands that you're trying unsuccessfully to use:
http://www.sparkfun.com/datasheets/Wireless/Zigbee/XBee-XCS-Manual.pdf
I believe that it's safe to say that you can't run ATND (or any of those other commands that gave you error messages) on the XSC version of the XBee. In at least some cases, there are replacements. For example, instead of ATDH and ATDL there's simply ATDT. ATGT is replaced with separate commands for guard time before (ATBT) and guard time after (ATAT). It looks like ATMY may be replaced with either ATID or ATMK.
There may be a way to mimic ATND, though I don't see it on a quick scan of the manual.
Post Edited (sylvie369) : 8/8/2009 5:59:15 PM GMT
Yes indeed, I had the wrong command set. What I had was for the regular XBees. The commands I was interested in do not exist in the XSC's command vocabulary, so I will have to do the ND function via some sort of more manual routine as far as I can tell. That ATND would have really been awesome...... alas. If you have a sudden flash of inspiration, feel free to share!
Dave
Still, I'll keep poking around with them. Have you thought about asking over on Martin Hebel's Yahoo Group (Selmaware)? Those folks seem to be a few steps ahead.
I started with the 900mHz units because I wanted to be sure beyond all doubt that the range I needed would be covered. I hope someday to get a chance to play with the 2.4g units, they seem to have some more useful commands for the types of apps I might want to put them in - at least for the ones where range is no issue.
Thanks again,
Dave
