issues with BS2P setup when serial cable is removed?
I have an application which is working fine when the laptop with the serial cable is connected. If it matters I have the serial plugged directly to a breadboard with the stamp. I went to unplug it to perform an installation / qualification of the new setup. At the point I disconnected it I heard a solenoid disengage. With out the computer hooked up to the BS2P it appears as thought the setup is not working evident by a SSR relay disengaging. I do have debug commands through out the program. Do I need to comment the debug commands out to run stand alone? Could there be some other issue. I haven't run into this before although I haven't used the debug much before either.
For what it is worth - This application utilizes two ADC0831's, and a SSR. I am using Pin# 0,1,2, and 3 to communicate with the ADC0831's.
Don't worry. Be happy
I did verify earlier that I had 5v at the cable going to the SSR. As soon as I would disconnect the serial cable from the laptop, the voltage would drop instantly.
Post Edited (l8_apex_it) : 8/7/2009 6:42:22 PM GMT
- Stephen
* Although, I do have pins#4 and #23 sharing the same ground. I've done this on most of my projects for some reason and don't ever remember having an issue before. Is this a bad practice? Could this explain the behavior I am seeing?
* I should have mentioned that I am using a DC/AC SSR. 5volts off of the BS2P with a 1k resistor. Due to it being a DC/AC resistor I don't belive I need the protecting diode correct?
thanks for the input. Since I need to document it anyway I will work on getting some schematics together.
- Stephen
