HT12D question
I have just added 3x HT12D receiver IC's to my stamp circuit. Anyone know how to stop the HT12D IC's starting up in 'latched on' mode? They clear once you send a valid transmission, but I cannot have them starting all latched on.
Steve
Steve
- Stephen
Don't worry. Be happy
I am simply driving a BC557 transistor on each output pin, so I don't believe they are contributing to the problem.
As it is the remote control receiver, it plays havoc with everything when the system boots up, as you everything operates! You have to quickly send a transmission on each channel to reset the HT12D.
Never simple is it!
They should not be starting in latched on mode anyway. The data sheet says they start low. I have tried new IC's but they are the same, and with the loads disconnected.... no different.
Its not the supply - checked that. Who knows!!!
