USB troubles
I made a prototype board and using the schematic included in this post and a propeller. I am communicating to a terminal program on a computer. I cant understand and its driving me nuts - when I exit the program running on the computer and restart it I loose coms with the propeller.
Any ideas?
Any ideas?
When you exit the program, it will close the COM port in use. When you restart the program, it will attempt to open the COM port.
Strange eh?
maybe the RTS-line is already toggled when closing the PC-application
it surely is toggled when you open the comport new and the toggling will reset the prop
does this appear if you store your program to EEPROM too ?
try PST.EXE from parallax which does NOT toggle the RTS-line when you open/close the comport
best regards
Stefan
Now, your problem is most likely DTR toggling in the Terminal program you are using. Try PST (Parallax Serial Terminal) or PropTerminal. These are built with knowledge of the DTR reset to the prop and they release the com port when they lose focus (switch back to PropTool).
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
· Search the Propeller forums (via Google)
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Again thanks
