µoled 96 prop
I have buyed currently the µOLED 96 PROP, yesterday I built two versions of a RS232 to TX-RX interfaces. One of them is the interface described in µOLED 96 G1 manual the other one is the interface (with a MAX232)·which is published in the propeller ·manual (the simple one with 2 transistors). All two don´t work, is it possible that the µOLED 96 PROP·do not react on this interfaces and I need a prop plug ?· The propeller development tool do not found the µOLED 96 PROP·on COM1. The µOLED 96 PROP·shows the demonstration program in a loop.·If I shorten the reset with ground the µOLED 96 PROP·doesn´t reset. The voltage of the interface is on 3.3V, produced by the µOLED 96 PROP. The voltage supply is 5V produced by an 78L05 chip.
Please has anyone an idea what is going wrong, is the µOLED 96 PROP·damaged, especially the reset line ?
Best regards
Christopher
Best regards
Christopher
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
I have changed my avatar so that I will no longer be confused with others who use genaric avatars.
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap·shipping unless specified!··········150 left!!··
Since you mention COM1, maybe you are using RS-232 from the PC. In that case, try this circuit:
http://www.parallax.com/DiagramsSchematicsandImages/tabid/254/Default.aspx
Good Luck,
Jim
perhaps the reset line needs a pullup resistor to +5V or +3.3 V, in the RS232 design, which I used the DTR line which occurs the reset has no connection to +5V or 3.3V. Is this possible a error ?
best regards
Christopher
Are you using an RS232 port on your computer or a USB to serial adapter? Not all USB to serial adapters will work for programming because they don't properly implement DTR.
thanks a lot for the answers, I used the RS232 with the MAX-IC it doesn´t work. If I shorten the reset pin with the GND Line the propeller in µOLED 96 doesn´t reset. I build an other propeller board with a RS232- 3 transistor solution some times ago, this unit works without troubles.
Is a defective reset line a possiblity ? If yes I hope I can sent the OLEd Prop unit retour to the manufacture.
Christopher
I built the 3 transistor RS232 interface, the reset pin is every time at 0V, the RS232 looks that it works but the propeller tool means that no contact to the processor is possible.· My opinion is that the internal pullup resistor is defect.
Best regard
Christopher
