I've seen the Z-80 emulator, could a SX emulator be done ?
Bean
I've seen the thread about the z-80 emulator.
Now that the SX is EOL'd I was wondering how difficult it would be to make an SX emulator.
Then Propeller users could enjoy the use of SX/B.
Any ideas how difficult this would be ? I know the timing would be different, and interrupt may not be possible, but I'd take those restrictions if you could run multiple SX/B programs on multiple cogs.
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
Post Edited (Bean (Hitt Consulting)) : 8/6/2009 9:16:33 PM GMT
Bean.
Yes it does...
Basically you'd have to write a word code interpreter. If I was doing it:
- 2K word or 4K word array in hub (code space)
- 137 / 262 bytes of ram - easiest if in the hub, or you can pack 3 per word easily (4 more slowly)
- stack in hub or cog
- there are only 43 "real" instructions, nice jump table takes care of that
The pains in the posterior would be:
- timers
- io pin modes not supported on the prop
- interrupts (as you mentioned) but they could be faked fairly easily by checking after each instruction
- SLOW compared to real thing
I think with a lot of work it might run at the speed of a 2MHz SX
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+ Advanced dual Propeller SBC with XMM and 256 Color VGA - PCB, kit, A&T available NOW!
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
· Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
· Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
· Search the Propeller forums (via Google)
I'm not the man for the job. After MoCog I will be done with emulators on the Prop. Must move on to other things.
Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-)
I have changed my avatar so that I will no longer be confused with others who use genaric avatars.
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order.
Cheap·shipping unless specified!··········150 left!!··
Thing is I don't have any historical, emotional, whatever attachment to the SX or any software that runs on it. So no motivation. A lot of my motivation has come from "software archaeology" as it were.
I am taken by the idea of the Apollo AGC on a Prop though. Especially since there is an existing AGC simulator written in C that we can get up and running with Catalina on a TriBlade or Morpheous board.
But I also want time for other interesting projects.....
