OpenGL Propeller Graphics
Just out of curiosity (and a bit of laziness), has anyone attempted to, or succeeded in creating an OpenGL/3D rendering environment for the Propeller? (Using a TV or VGA Monitor, of course).
Aaron.
Aaron.
Composite NTSC sprite driver: Forum
NTSC & PAL driver templates: ObEx Forum
OnePinTVText driver: ObEx Forum
Now if someone had a lot of time, after i get a few more graphics drivers written for Morpheus, it should be doable - if slow.
Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
Morpheus & Mem+ Advanced dual Propeller SBC with XMM and 256 Color VGA - PCB, kit, A&T available NOW!
www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
(X axis resolution) * (Y axis resolution) * (Bits per pixel) / 8 = bytes needed for one frame buffer
Really, the larger memory and compute consumption comes from the geometry, lighting, transform and texture data required for projection onto the frame buffer. For any kind of real time interaction, a lot of memory beyond the frame buffer is required, along with significant compute.
Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
Safety Tip: Life is as good as YOU think it is!
