* Request Circuit Connection Diagram and BS2 sample code for ADC0838 *
Dear all,
Recently I have a robotic project where need to control 8 pieces of Potentialmeter to my BS2 board, at such, I have found some related info and finally think ADC0831 can suit to my requirement (Refer Picture 1 and Picture 2), however, each ADC0831 required 3 input pins to BS2 board or in simply it needs (8 x 3) = 24 input pins, ·so I don’t think BS2 can have enough pin to handle this.
After I read through ADC0831 datasheet, I realized that another IC ADC0838 where it has 8 channels for single chip, but I really don’t know how to connect it to my stamp board as I try to search through the internet, does any could help to provide stamp code (BS2) ·and circuit connection diagram to me.
Your valued comment is greatly appreciated!
Best Regard,
Efly
Best Regard,
Efly
It has 11 input channels and 12-bit resolution.
' {$STAMP BS2} ' {$PBASIC 2.5} ' Test code for TLC1543CN 12-bit ADC. 11 analog inputs. ' -------------------------------------------------------------------------------------------- sclk PIN 1 ' clock out from BS2 sdo PIN 2 ' data from BS2 to ADC sdi PIN 3 ' data to BS2 ADcs PIN 4 ' chip select, active low ADch VAR Nib ' selects AD external channel 0-10 result VAR Word ' result, 12 bit A/D conversion demo: ' to show off the subroutine below. LOW ADcs DO GOSUB ADwake ' makes a dummy conversion to initialize converter FOR ADch =0 TO 10 ' specify one of 11 input channels GOSUB ADread ' get millivolt data from that channel result = 14464 ** result + result ' convert count to millivolts. DEBUG DEC ADch,": ",DEC result,REP 32\5,CR ' display, use extra spaces to clear garbage NEXT GOSUB ADsleep 'NAP 1 DEBUG HOME ' repeat the demo LOOP ADread: ' entry point to give result as count from 0 to 4095 LOW ADcs ' select chip SHIFTOUT sdo,sclk,MSBFIRST,[noparse][[/noparse]ADch<<8\12] ' mode, left justify ADch SHIFTIN sdi,sclk,MSBPRE,[noparse][[/noparse]result\12] ' get result, 12 bits HIGH ADcs ' deselect chip RETURN ADsleep: ' entry point to put TLC2543 to sleep LOW ADcs ' select chip SHIFTOUT sdo,sclk,MSBFIRST,[noparse][[/noparse]$e\4] ' command=$e HIGH ADcs ' deselect chip LOW sdi ' keep this pin from floating in sleep RETURN ADwake: ADch=$b GOTO ADread▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Don't worry. Be happy
