CT or other means of monitoring an overloaded circuit
I am looking for an cheap means of monitoring the current of a 110v 1 HP AC motor that I want to start and stop using basic stamp. I have foud some very small Current Transformers that are board mountable but there are dangers associated with them if the wrong person got to tinkering with my project (you never know) the ct's can be lethal. So if anyone has done anything like this with· ct or what ever I would appreciate you help. THanks..
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
- Stephen
Voltage changes with current, so rctime should show that your current has changed.
Parallax also has a hall effect sensor. You generally don't need opto isolation if you use a hall effect sensor, since it's physically detached from the sensing current, but it's a good safety measure.
Don't worry. Be happy
Cmon, its all relative!
Ohms law states that if you change either voltage, current, or resistance, ONE of the three must change with it, Period. Try it with a motor, lock the rotor(simulating load/current increase), and tell me that your voltage doesn't change.
In your example there is so much power dissipated that your power source is drained so quickly it will show up on a voltmeter.
In any case, you cannot measure mains current by measuring a resulting DC voltage or current in the Stamp. A Hall effect sensor or a current transformer is the only way to go.
Yes, and it's the current that changes not the voltage (keep to the topic of the thread, we are talking about mains voltage)!
oops. never mind. much different situation when you have direct mains. perhaps the words "overloaded circuit" threw me off.
