Switching regulator recommendation
I have typed this sort of thing into electronics websites search engines before, but as you well know, you get somewhere between 1 and 100 billion results, and I don't know what to pick, and I know you guys can show me some common approaches, and some readily available part numbers.
Can one of you fine gentlemen recommend a good way/part number for accomplishing the following task:
- Output 5 or 6vdc (either, or anything in between will be fine)
- Output capable of ~3A (more is fine)
- Input voltage of between ~9 and ~14vdc (normally between ~11 and ~13.5vdc)
- And some kind of through hole package. Preferably a DIP package, although the "TO" package would work as well.
If you guys can help point me in the right direction on some common IC's for that I would appreciate it. There are just so many things I run into, and so many ways of doing that, that I have no idea what would be the most practical thing to use.
I have never tried to put together a regulator before.
start filling in feilds you care about and press apply.
there are only 54 items with TO* package 5 or 6v output 3+A
propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
lt's not particularly silly, is it?
