Write/Read multiple Variables using BS2
Hey all, I know there has to be an easier way of doing this... I've spent a lot of time doing this long hand and it failed to build, so I would like someones help with the programming to both condense and understand an easy way of accomplishing the code attached... I'm trying to input a 4-bit number, store it in memory, enter another 4-bit number store it in memory, then enter one more 4-bit number store it in memory. Then I'd like to be able to call the entered numbers out of memory to perform a math equation then output the answer via serial.
Thank you ahead of time for all your help. It's really appreciated!!!
Covert
' {$STAMP BS2}
' {$PBASIC 2.5}
'--------------------------------------[noparse][[/noparse]Variable Declarations]---------------------------------------------------
ParIn1 VAR IN4 'Parallel Input Bit 1
ParIn2 VAR IN5 'Parallel Input Bit 2
ParIn3 VAR IN6 'Parallel Input Bit 3
ParIn4 VAR IN7 'Parallel Input Bit 4
Ans VAR Byte 'Answer Equals 8 Bits
Com1 VAR Nib 'Combined 4-bits to make 1
Com2 VAR Nib 'Combined 4-bits to make 2
Com3 VAR Nib 'Combined 4-bits to make 3
Com4 VAR Nib 'Combined 4-bits to make 4
Com5 VAR Nib 'Combined 4-bits to make 5
Com6 VAR Nib 'Combined 4-bits to make 6
Com7 VAR Nib 'Combined 4-bits to make 7
Com8 VAR Nib 'Combined 4-bits to make 8
Com9 VAR Nib 'Combined 4-bits to make 9
Com0 VAR Nib 'Combined 4-bits to make 0
ComPl VAR Nib 'Combined 4-bits to make +
ComMi VAR Nib 'Combined 4-bits to make -
ComEq VAR Nib 'Combined 4-bits to make =
'-----------------------------------------[noparse][[/noparse]Set Value Types]------------------------------------------------------
Com1 = %0001 'Setting Binary Bits for Decimal 1
Com2 = %0010 'Setting Binary Bits for Decimal 2
Com3 = %0011 'Setting Binary Bits for Decimal 3
Com4 = %0100 'Setting Binary Bits for Decimal 4
Com5 = %0101 'Setting Binary Bits for Decimal 5
Com6 = %0110 'Setting Binary Bits for Decimal 6
Com7 = %0111 'Setting Binary Bits for Decimal 7
Com8 = %1000 'Setting Binary Bits for Decimal 8
Com9 = %1001 'Setting Binary Bits for Decimal 9
Com0 = %1010 'Setting Binary Bits for Decimal 10
ComMi= %1011 'Setting Binary Bits for Decimal 11
ComEq= %1100 'Setting Binary Bits for Decimal 12
ComPl= %1101 'Setting Binary Bits for Decimal 13
'----------------------------------------------[noparse][[/noparse]Main Routine]----------------------------------------------------
Main:
GOSUB Var1:
'-----------------------------------------[noparse][[/noparse]First Variable Key Scan]----------------------------------------------
Var1:
'Main Subroutine
IF (ParIn1 = 1 AND ParIn2 = 1 AND ParIn3 = 1 AND ParIn4 = 1) THEN 'Checking Bits for Binary 1111
DEBUG " Welcome... Please enter Number ", CR 'Displaying Opening Screen
PAUSE 1000 'Pause for 1 Second
ENDIF 'End Statement
DO 'Begin Loop
IF (ParIn1 = 1 AND ParIn2 = 0 AND ParIn3 = 0 AND ParIn4 = 0) THEN 'Checking bits for Binary 0001 (1)
DEBUG IBIN4 Com1, CR 'Display 4-bit Binary by calling Com1
'SEROUT 1, 9600, [noparse][[/noparse]Com1, CR] 'Serially send 4-bit Code Out
WRITE 101, Com1 'Write the Value Com1 at location 101
GOSUB PlMi: 'Go to Subroutine PlMi
ELSEIF (ParIn1 = 0 AND ParIn2 = 1 AND ParIn3 = 0 AND ParIn4 = 0) THEN 'Checking bits for Binary 0010 (2)
DEBUG IBIN4 Com2, CR 'Display 4-bit Binary by calling Com2
'SEROUT 1, 9600, [noparse][[/noparse]Com2, CR] 'Serially Send 4-bit Code Out
WRITE 102, Com2 'Write the Value Com2 at location 102
ELSEIF (ParIn1 = 1 AND ParIn2 = 1 AND ParIn3 = 0 AND ParIn4 = 0) THEN 'Checking bits for Binary 0011 (3)
DEBUG IBIN4 Com3, CR 'Display 4-bit Binary by calling Com3
'SEROUT 1, 9600, [noparse][[/noparse]Com3, CR] 'Serially Send 4-bit Code Out
WRITE 103, Com3 'Write the Value Com3 at location 103
ELSEIF (ParIn1 = 0 AND ParIn2 = 0 AND ParIn3 = 1 AND ParIn4 = 0) THEN 'Checking bits for Binary 0100 (4)
DEBUG IBIN4 Com4, CR 'Display 4-bit Binary by calling Com4
'SEROUT 1, 9600, [noparse][[/noparse]Com4, CR] 'Serially Send 4-bit Code Out
WRITE 104, Com4 'Write the Value Com4 at location 104
ELSEIF (ParIn1 = 1 AND ParIn2 = 0 AND ParIn3 = 1 AND ParIn4 = 0) THEN 'Checking bits for Binary 0101 (5)
DEBUG IBIN4 Com5, CR 'Display 4-bit Binary by calling Com5
'SEROUT 1, 9600, [noparse][[/noparse]Com5, CR] 'Serially Send 4-bit Code Out
WRITE 105, Com5 'Write the Value Com5 at location 105
ELSEIF (ParIn1 = 0 AND ParIn2 = 1 AND ParIn3 = 1 AND ParIn4 = 0) THEN 'Checking bits for Binary 0110 (6)
DEBUG IBIN4 Com6, CR 'Display 4-bit Binary by calling Com6
'SEROUT 1, 9600, [noparse][[/noparse]Com6, CR] 'Serially Send 4-bit Code Out
WRITE 106, Com6 'Write the Value Com6 at location 106
ELSEIF (ParIn1 = 1 AND ParIn2 = 1 AND ParIn3 = 1 AND ParIn4 = 0) THEN 'Checking bits for Binary 0111 (7)
DEBUG IBIN4 Com7, CR 'Display 4-bit Binary by calling Com7
'SEROUT 1, 9600, [noparse][[/noparse]Com7, CR] 'Serially Send 4-bit Code Out
WRITE 107, Com7 'Write the Value Com7 at location 107
ELSEIF (ParIn1 = 0 AND ParIn2 = 0 AND ParIn3 = 0 AND ParIn4 = 1) THEN 'Checking bits for Binary 1000 (8)
DEBUG IBIN4 Com8, CR 'Display 4-bit Binary by calling Com8
'SEROUT 1, 9600, [noparse][[/noparse]Com8, CR] 'Serially Send 4-bit Code Out
WRITE 108, Com8 'Write the Value Com8 at location 108
ELSEIF (ParIn1 = 1 AND ParIn2 = 0 AND ParIn3 = 0 AND ParIn4 = 1) THEN 'Checking bits for Binary 1001 (9)
DEBUG IBIN4 Com9, CR 'Display 4-bit Binary by calling Com9
'SEROUT 1, 9600, [noparse][[/noparse]Com9, CR] 'Serially Send 4-bit Code Out
WRITE 109, Com9 'Write the Value Com9 at location 109
ELSEIF (ParIn1 = 0 AND ParIn2 = 1 AND ParIn3 = 0 AND ParIn4 = 1) THEN 'Checking bits for Binary 1010 (0)
DEBUG IBIN4 Com0, CR 'Display 4-bit Binary by calling Com0
'SEROUT 1, 9600, [noparse][[/noparse]Com0, CR] 'Serially Send 4-bit Code Out
WRITE 100, Com0 'Write the Value Com0 at location 100
ELSE 'If NO pushbuttons are active
GOTO Var1: 'Return to the top and scan again
ENDIF 'End Statment
LOOP 'End Loop
'---------------------------------------------[noparse][[/noparse]Addition/Subtraction Subroutine]----------------------------------------
PlMi:
DO
IF (ParIn1 = 1 AND ParIn2 = 0 AND ParIn3 = 1 AND ParIn4 = 1) THEN 'Checking bits for Binary 1011 (-)
DEBUG IBIN4 ComMi, CR 'Display 4-bit Binary by calling ComMi
'SEROUT 1, 9600, [noparse][[/noparse]ComMi, CR] 'Serially Send 4-bit Code Out
WRITE 111, ComMi 'Write the Value ComMi at location 111
GOSUB Var2: 'Go to Subroutine Var2
ELSEIF (ParIn1 = 1 AND ParIn2 = 0 AND ParIn3 = 1 AND ParIn4 = 1) THEN 'Checking bits for Binary 1101 (+)
DEBUG IBIN4 ComPl, CR 'Display 4-bit Binary by calling ComPl
'SEROUT 1, 9600, [noparse][[/noparse]ComPl, CR] 'Serially Send 4-bit Code Out
PAUSE 1000 'Pause for 1 Sencond
WRITE 113, ComPl 'Write the Value ComPl at Location 113
ELSE
GOSUB PlMi:
ENDIF
LOOP
'---------------------------------------[noparse][[/noparse]Second Variable Subroutine]---------------------------------------------
Var2:
DO 'Begin Loop
WRITE 121, Com1 'Write the Value Com1 at location 121
GOSUB Equ: 'Go to Subroutine Equ
WRITE 122, Com2 'Write the Value Com2 at location 122
WRITE 123, Com3 'Write the Value Com3 at location 123
WRITE 124, Com4 'Write the Value Com4 at location 124
WRITE 125, Com5 'Write the Value Com5 at location 125
WRITE 126, Com6 'Write the Value Com6 at location 126
WRITE 127, Com7 'Write the Value Com7 at location 127
WRITE 128, Com8 'Write the Value Com8 at location 128
WRITE 129, Com9 'Write the Value Com9 at location 129
WRITE 120, Com0 'Write the Value Com0 at location 120
GOTO Equ: 'Return to the top and scan again
ENDIF 'End Statment
LOOP 'End Loop
'-----------------------------------------------[noparse][[/noparse]Equating Subroutine]--------------------------------------------
Equ:
READ 101, Com1
READ 102, Com2
READ 103, Com3
READ 104, Com4
READ 105, Com5
READ 106, Com6
READ 107, Com7
READ 108, Com8
READ 109, Com9
READ 100, Com0
READ 121, Com1
READ 122, Com2
READ 123, Com3
READ 124, Com4
READ 125, Com5
READ 126, Com6
READ 127, Com7
READ 128, Com8
READ 129, Com9
READ 120, Com0
READ 111, ComMi
READ 113, ComPl
DO
IF ComPl THEN
(Com0 + Com1 = %00000001) OR (Com0 + Com2 = %00000010) OR (Com0 + Com3 = %00000011) OR (Com0 + Com4 = %00000100) OR
(Com0 + Com5 = %00000101) OR (Com0 + Com6 = %00000110) OR (Com0 + Com7 = %00000111) OR (Com0 + Com8 = %00001000) OR
(Com0 + Com9 = %00001001) OR
(Com1 + Com1 = %00000010) OR (Com1 + Com2 = %00000011) OR (Com1 + Com3 = %00000100) OR (Com1 + Com4 = %00000101) OR
(Com1 + Com5 = %00000110) OR (Com1 + Com6 = %00000111) OR (Com1 + Com7 = %00001000) OR (Com1 + Com8 = %00001001) OR
(Com1 + Com9 = %00001010) OR
(Com2 + Com1 = %00000011) OR (Com2 + Com2 = %00000100) OR (Com2 + Com3 = %00000101) OR (Com2 + Com4 = %00000110) OR
(Com2 + Com5 = %00000111) OR (Com2 + Com6 = %00001000) OR (Com2 + Com7 = %00001001) OR (Com2 + Com8 = %00001010) OR
(Com2 + Com9 = %00001011) OR
(Com3 + Com1 = %00000100) OR (Com3 + Com2 = %00000101) OR (Com3 + Com3 = %00000110) OR (Com3 + Com4 = %00000111) OR
(Com3 + Com5 = %00001000) OR (Com3 + Com6 = %00001001) OR (Com3 + Com7 = %00001010) OR (Com3 + Com8 = %00001011) OR
(Com3 + Com9 = %00001100) OR
(Com4 + Com1 = %00000101) OR (Com4 + Com2 = %00000110) OR (Com4 + Com3 = %00000111) OR (Com4 + Com4 = %00001000) OR
(Com4 + Com6 = %00001010) OR (Com4 + Com7 = %00001011) OR (Com4 + Com8 = %00001100) OR (Com4 + Com9 = %00001101) OR
(Com4 + Com5 = %00001001) OR
(Com5 + Com1 = %00000110) OR (Com5 + Com2 = %00000111) OR (Com5 + Com3 = %00001000) OR (Com5 + Com4 = %00001001) OR
(Com5 + Com5 = %00001010) OR (Com5 + Com6 = %00001011) OR (Com5 + Com7 = %00001100) OR (Com5 + Com8 = %00001101) OR
(Com5 + Com9 = %00001110) OR
(Com6 + Com1 = %00000111) OR (Com6 + Com2 = %00001000) OR (Com6 + Com3 = %00001001) OR (Com6 + Com4 = %00001010) OR
(Com6 + Com5 = %00001011) OR (Com6 + Com6 = %00001100) OR (Com6 + Com7 = %00001101) OR (Com6 + Com8 = %00001110) OR
(Com6 + Com9 = %00001111) OR
(Com7 + Com1 = %00001000) OR (Com7 + Com2 = %00001001) OR (Com7 + Com3 = %00001010) OR (Com7 + Com4 = %00001011) OR
(Com7 + Com5 = %00001100) OR (Com7 + Com6 = %00001101) OR (Com7 + Com7 = %00001110) OR (Com7 + Com8 = %00001111) OR
(Com7 + Com9 = %00010000) OR
(Com8 + Com1 = %00001001) OR (Com8 + Com2 = %00001010) OR (Com8 + Com3 = %00001011) OR (Com8 + Com4 = %00001100) OR
(Com8 + Com5 = %00001101) OR (Com8 + Com6 = %00001110) OR (Com8 + Com7 = %00001111) OR (Com8 + Com8 = %00010000) OR
(Com8 + Com9 = %00010001) OR
(Com9 + Com1 = %00001010) OR (Com9 + Com2 = %00001011) OR (Com9 + Com3 = %00001100) OR (Com9 + Com4 = %00001101) OR
(Com9 + Com5 = %00001110) OR (Com9 + Com6 = %00001111) OR (Com9 + Com7 = %00010000) OR (Com9 + Com8 = %00010001) OR
(Com9 + Com9 = %00010010) OR
DEBUG IBIN8 Ans, CR
PAUSE 1000
GOTO Main:
ELSEIF ComMi THEN
(Com0 - Com1 = %00000001) OR (Com0 - Com2 = %00000010) OR (Com0 - Com3 = %00000011) OR (Com0 - Com4 = %00000100) OR
(Com0 - Com5 = %00000101) OR (Com0 - Com6 = %00000110) OR (Com0 - Com7 = %00000111) OR (Com0 - Com8 = %00001000) OR
(Com0 - Com9 = %00001001) OR
(Com1 - Com1 = %00000010) OR (Com1 - Com2 = %00000011) OR (Com1 - Com3 = %00000100) OR (Com1 - Com4 = %00000101) OR
(Com1 - Com5 = %00000110) OR (Com1 - Com6 = %00000111) OR (Com1 - Com7 = %00001000) OR (Com1 - Com8 = %00001001) OR
(Com1 - Com9 = %00001010) OR
(Com2 - Com1 = %00000011) OR (Com2 - Com2 = %00000100) OR (Com2 - Com3 = %00000101) OR (Com2 - Com4 = %00000110) OR
(Com2 - Com5 = %00000111) OR (Com2 - Com6 = %00001000) OR (Com2 - Com7 = %00001001) OR (Com2 - Com8 = %00001010) OR
(Com2 - Com9 = %00001011) OR
(Com3 - Com1 = %00000100) OR (Com3 - Com2 = %00000101) OR (Com3 - Com3 = %00000110) OR (Com3 - Com4 = %00000111) OR
(Com3 - Com5 = %00001000) OR (Com3 - Com6 = %00001001) OR (Com3 - Com7 = %00001010) OR (Com3 - Com8 = %00001011) OR
(Com3 - Com9 = %00001100) OR
(Com4 - Com1 = %00000101) OR (Com4 - Com2 = %00000110) OR (Com4 - Com3 = %00000111) OR (Com4 - Com4 = %00001000) OR
(Com4 - Com6 = %00001010) OR (Com4 - Com7 = %00001011) OR (Com4 - Com8 = %00001100) OR (Com4 - Com9 = %00001101) OR
(Com4 - Com5 = %00001001) OR
(Com5 - Com1 = %00000110) OR (Com5 - Com2 = %00000111) OR (Com5 - Com3 = %00001000) OR (Com5 - Com4 = %00001001) OR
(Com5 - Com5 = %00001010) OR (Com5 - Com6 = %00001011) OR (Com5 - Com7 = %00001100) OR (Com5 - Com8 = %00001101) OR
(Com5 - Com9 = %00001110) OR
(Com6 - Com1 = %00000111) OR (Com6 - Com2 = %00001000) OR (Com6 - Com3 = %00001001) OR (Com6 - Com4 = %00001010) OR
(Com6 - Com5 = %00001011) OR (Com6 - Com6 = %00001100) OR (Com6 - Com7 = %00001101) OR (Com6 - Com8 = %00001110) OR
(Com6 - Com9 = %00001111) OR
(Com7 - Com1 = %00001000) OR (Com7 - Com2 = %00001001) OR (Com7 - Com3 = %00001010) OR (Com7 - Com4 = %00001011) OR
(Com7 - Com5 = %00001100) OR (Com7 - Com6 = %00001101) OR (Com7 - Com7 = %00001110) OR (Com7 - Com8 = %00001111) OR
(Com7 - Com9 = %00010000) OR
(Com8 - Com1 = %00001001) OR (Com8 - Com2 = %00001010) OR (Com8 - Com3 = %00001011) OR (Com8 - Com4 = %00001100) OR
(Com8 - Com5 = %00001101) OR (Com8 - Com6 = %00001110) OR (Com8 - Com7 = %00001111) OR (Com8 - Com8 = %00010000) OR
(Com8 - Com9 = %00010001) OR
(Com9 - Com1 = %00001010) OR (Com9 - Com2 = %00001011) OR (Com9 - Com3 = %00001100) OR (Com9 - Com4 = %00001101) OR
(Com9 - Com5 = %00001110) OR (Com9 - Com6 = %00001111) OR (Com9 - Com7 = %00010000) OR (Com9 - Com8 = %00010001) OR
(Com9 - Com9 = %00010010) OR
DEBUG IBIN8 Ans, CR
PAUSE 1000
GOTO Main:
ELSE
GOTO Equ:
ENDIF
LOOP
'---------------------------------------[noparse][[/noparse]End of Program Subroutine]----------------------------------------------
END
Covert
You should make your "Com#" variables an array of nibs, rather than a series of named variables. I believe that PBASIC will allow you to access it as an array anyway, but you don't really need the names...
Your initialization of the com array should be done in a loop. You're just setting each one to n (where n is your counter/index). Some psuedo code:
For this line: IF (ParIn1 = 1 AND ParIn2 = 1 AND ParIn3 = 1 AND ParIn4 = 1) THEN you can substitute the nib alias and compare it to %1111. Look in the PBASIC manual, it's something like INB.
You have "Com0 + Com5 = %00000101" and other similar variants in the big OR blocks. First, what is the purpose of the OR block? Isn't an OR (in this case) a logical (boolean) operator, not an arithmetic operator? Anyway, if you're sure that you want that block then I'm pretty sure that you "Com0 + Com5 = %00000101" will never be possible. The since the Com# can each be either 0 or 1, the highest value when added is two.
For the rest of your code, study up on how to use a FOR loop. Then, look at the patters that you see in your code, and try and determine if you can smash it into a loop. The beginning of Equ would be a good place to start (all those reads are begging to be in a loop). The subroutines Var1 and Var2 could probably be combined, then made much more efficient. Some more detail on what you're trying to accomplish will help any further answers. Specifically, exactly what each section of code is supposed to do (embodied as comments in the code every 5-10 lines or so).
A valiant effort. But I think Your way over thinking everything.
I would read through the serial chapters again.
I'm an old school programmer from the TRS-80 days, I could do this back then (20 years ago) with far less code.
If it was easy, We wouldn't be here.
_______________$WMc%_____
The Truth is out there············································ BoogerWoods, FL. USA
Without getting too fancy, how about something like,
x VAR Nib ' x value y VAR Nib ' y value op VAR Nib ' operator + or - z VAR Word ' result (can be negative, so a Word value is specified) dnib VAR inB ' alias for the input pins p4 to p7, which are also called inB pushbutton VAR in0 ' this is the ENTER button, low to enter data, when this goes low, the Stamp knows the data is valid. [noparse][[/noparse]code]DEBUG "Enter a nib and push the enter button",CR DO x=dNib ' read data nib on pins p4 to p7 LOOP UNTIL pushbutton=0 AND x<10 ' user enters valid x DO : LOOP UNTIL pushbutton=1 ' wait for button up DEBUG "Enter + or - and push the enter button",CR DO x=dNib ' read nib on pins p4 to p7 LOOP UNTIL pushbutton=0 AND (x=11 OR x=13) ' user enters + or - DO : LOOP UNTIL pushbutton=1 ' wait for button up DEBUG "Enter a nib and push the enter button",CR DO y=dNib ' read nib on pins p4 to p7 LOOP UNTIL pushbutton=0 AND x<10 ' user enters second value DO : LOOP UNTIL pushbutton=1 ' wait for button up If op=11 THEN z =x - y ELSE z = x + y DEBUG SDEC z,CR LOOPedit: more consistent notation, typo
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 8/6/2009 3:42:29 PM GMT
For a Senior Project I've designed and built a DTMF Encoder and Decoder with a built calculator interface (just momentary switches connected to my circuit). On the output of my Decoder I have a 4-Bit Binary Coded Decimal signal, via my parallel input to my BS2. Every momentary switch has a specific BCD output (such as 0001 (1) through 1101 (13)).
On the BS2 side of this project my ultimate goals are to calculate the inputs (either addition or subtraction depending on what the user decides on) and to convert it to serial for wireless transmission (which has been taken care of by another teammate). As far as the calculator operation goes I'd like to receive a number (triggered by one momentary switch on the calculator interface, such as 0001 (1)), then receive an operand (addition is BCD 1101 (13) and subtraction is 1011 (11)), then receive the second variable (such as 0010 (2)), then calculate the sum or difference. Finally to finish it off I'd like to receive the last button (Equals sign, BCD 1100 (12)), at this point it should send just the answer serially.
Also when looking at my code you'll notice that after every entry I'd like to send it serially. On the receiving end of my transmission there is another BS2 (this is a teammates part) programmed to receive a byte after each button is pushed so that a robotic arm can write the individual number, then wait for the next number to be entered and so on.
as far as my code goes for right now, I know:
My "First Variable Key Scan" (Var1), works how I need it too, it's really long hand though if you get what I mean. But every time a button is pushed the debug window shows the BCD output, which is what I'd like to see. But just having thirteen BCD outputs isn't enough, I need these BCD digits to be either added or subtracted (which is one reason I moved from the two nibbles to a byte), unfortunately I'm unsure how to either store the numbers entered momentarily while the program retrieves the other numbers, or if I have to actually save the numbers. On the other hand, like Tracy Allen had mentioned, I'm not to sure how to separate all my variable nibbles..?
The whole "OR BLOCKS" are being used because I really couldn't think of another way to accomplish what I wanted without first scanning through each option until the right ones found. I'm not trying to use it as a mathematics operator, but as an actual OR, so yes, like a Boolean operator...
If this still isn't enough, or if you have other questions on what I'm trying to accomplish I'll get back to you much faster than this... Thank you guys soooo much for all your help, I really appreciate it!
