slightly faster Simple_Serial
Hi, All.
OK, this won't be of too much use to most people, but I noticed that the simple_serial.spin code wasn't overly efficient in the actual sending and receiving of bits. I re-worked it a little, saved a few longs, but most importantly on an 80 MHz system, the speed limit used to be 19200 bps. With the reworked version I can do 31250 bps (but not 38400) on the same system.
Here are the relevant bits:
Jonathan
lonesock
Piranha are people too.
PUB rx: rxByte | t
{{ Receive a byte; blocks caller until byte received. }}
if rxOkay
dira[noparse][[/noparse]sin]~ ' make rx pin an input
t := bitTime >> 1 ' 1/2 a bit
waitpeq(inverted & |< sin, |< sin, 0) ' wait for start bit
t += cnt ' sync + 1/2 bit
repeat 8
waitcnt(t += bitTime) ' wait for middle of bit
rxByte += ina[noparse][[/noparse]sin] + rxByte ' sample bit
waitcnt(t + bitTime) ' allow for stop bit
rxByte := (rxByte >< 8) ^ inverted ' adjust for mode and strip off high bits
PUB tx(txByte) | t
{{ Transmit a byte; blocks caller until byte transmitted. }}
if txOkay
txByte := ((txByte | $100) << 2) ^ inverted ' add stop bit, set mode
outa[noparse][[/noparse]sout] := !inverted ' set idle state
t := cnt ' sync
dira[noparse][[/noparse]sout]~~ ' make tx pin an output
repeat 10 ' start + eight data bits + stop
waitcnt(t += bitTime) ' wait bit time
outa[noparse][[/noparse]sout] := (txByte >>= 1) ' output bit (true mode)
dira[noparse][[/noparse]sout] := sout <> sin ' release to pull-up/pull-down
Jonathan
lonesock
--Steve
Propalyzer: Propeller PC Logic Analyzer
http://forums.parallax.com/showthread.php?p=788230
thanks,
Jonathan
lonesock
