Ping Distance with Ball Detection
Hey guys,
first of all: great Forum!
I am currently building a ball and beam system for my university, where the ball rolling on the beam is detected by two Ping Sensors, each one at one end of it. Now the sensors have a theoretical range of a 3m (118in), however, with detecting a round object that reflects only very little energy, the distance decreases to about 20cm (8in). Even with two sensors I cannot cover the whole beam which is about 24in long. The sensors don't interfere, as only one is working at one time and they change after the ball bypassed a certain position (at least in theory). So guys, my questions for you:
Is there any way how I can increase the range of both sensors? E.g with:
- attaching them in a different position to the beam (vertical rather than horizontal). Actually tried but without any effect.
- using a more reflective object (ball). Right now I have a rubber ball with smooth surface, about 1.5in diameter.
- using a bigger object (ball)
- increasing the temperature: In my old office it was much warmer than here in my new one and the sensors seem have to cover nearly double the length
- changing the supply cable: Each sensor sits on a 3ft long cable, unshielded. Within the 8in range, the sensors work perfectly accurate and fast though.
- changing the software (see attached)
- considering that the Ping sensors work different in debug mode (4Mhz) than in stand alone mode (50Mhz) (doubt that actually, but who knows?)
If I cannot increase the range of the sensors, what alternative methods do you recommend to detect a 1.5 in dia ball on a 24in long beam?
Thanks guys, very much!
Matthias from Germany in the US
CODE
Post Edited (Matthias09) : 8/4/2009 1:02:38 AM GMT
CODE
Rich H
The Linescan sensor is a single pixel row camera, it has a field of view approximately equal to it's distance from what it is viewing. If you could mount it on an arm above the beam, so that it moves with the beam, I think it would work. If the beam only rocks a small amount then it probably wouldn't need to be attached to the beam, but it would still need to be on an arm that is fixed in the plane that the beam moves in.
Rich H
Thanks Guys!
Nevertheless: thank you LilDi for giving me this hint. I appreciate!
Matthias
Searider
thank you for the ideas. To keep the system simple I will either use the camera or two sensors, not both together. You talked about IR sensors. The point is that these Sharp IR sensors are not better regarding range than the Ultrasonic ones I have. So I could stick with them. But anyway, adding a third sensor sounds to complex for, and my professors will ask me why I cannot do it with one or two (as there are ways to do it)
@Searider
thank you too! I had this resistive wire idea also in my mind, however, after googling, I could not find any appropriate materials to use as well as an idea, how to set up the system. I know basically, that you connect one wire to a power source (e.g. 9V) and the other to the A/D converter. But are there some additional electronics necessary (to filter, amplify, smoothen, ... the signal)? What A/D converter would you recommend?
@all
looks like the Ultrasonic sensors are not appropriate for this project, as I received alternative solutions, but not any that suggest improvements of the range (like I stated in my first post)?
Checkout Resitancewire.com They don't sell online but there website says that they sell small quanities to hobbiest. You might call them and tell them what you are doing.
Just about any A/D would work. There is even a way to do A/D with only resistors and capacitors and using the Prop.
You can also check the Parallax store for A/D converters.
I would think you would hook one wire to a voltage source (a resistor in series would prevent and acidental short circuit. It could be large because you only care about voltage, not current.
Hook the other end to a resistor that goes to ground
Measure the voltage where you connect the wire to the ground resistor. You now have three resistors in series with the middle one being variable. You can size the two fixed resistores to scale the input to the proper range for your A/D converter.
Searider
