Problem with DynamicMathLib
electric550
Has anybody experiance problems withe the FCos(a), FSin(a), FTan(a) commands in the DynamicMathLib? The other functions are working fine for me but the ones mentioned are getting stuck in a loop when the function is called, so the program just stops. Any suggestions.
The above functions are locking up when I run them. I was wondering if anyone had a similar problem or if someone knows how to fix this? Thanks
Also the degree version of the commands return from the loop but they are returning incorrect values when I run them.
Post Edited (electric550) : 8/3/2009 2:49:19 AM GMT
con ''These are from Float32 and require a cog no matter what PUB FSin(a) restart1 'return sendCmd(SinCmd + @a) command := SinCmd + @a repeat while command stop1 return cmdReturn PUB FCos(a) 'return sendCmd(CosCmd + @a) command := CosCmd + @a repeat while command return cmdReturn PUB FTan(a) restart 'return sendCmd(TanCmd + @a) command := TanCmd + @a repeat while command stop1 return cmdReturn
and it works now.
