PIR sensor to relay
Ive got a project I am looking to complete and need some help.
I have a event counter that is hooked up to a PIR sensor with a +(red),-(white),out? (yellow)inputs.
I want to convert the pir to a switch to trigger a event.
So i am wondering how i do this.
I thought if i touch out(yellow) to the -(white) it would trigger a count but it doesnt.
I get 2.77V when i·test red and white and 2.77V when i test red and yellow.
What do i need to trigger a event by using a switch/wires as opposed to a PIR sensor.
Thanks for any input.
Dan
Dan
- Stephen
Here is a sample schematic for triggering a timer and a relay with a PIR: http://forums.parallax.com/showthread.php?p=826065
Don't worry. Be happy
I have a premade event counter that is set up to accept signals from a PIR sensor.
Here is a pic of the premade event counter and the PIR sensor hooks up to "sensor 1" on the R, W, Y which correlates with +,-, input
Instead of using a PIR, i want to use a switch.
I tried the parallax pir sensor on this premade event counter and it works. So i was thinking someone on this site would know how to use a switch to mimic the signals of the PIR.
- Stephen
This is a great forum.
