Faster LMM Code: Not reversed this time. (IMPORTANT Addendum in Top Post) — Parallax Forums
edited 2012-12-10 11:10 in Propeller 1
The "standard" LMM kernel, first devised by Bill Henning, uses a loop like this:
lmm_loop      rdlong    instr,pc                'Read the next instruction.
              add       pc,#4                   'Increment the PC.
instr         long      0-0                     'Execute the instruction.
              jmp       #lmm_loop               'Loop back for next instruction.
This misses the hub sweet spot by one instruction, thereby lengthening the execution time. In order to hit the sweet spot, I came up with the reverse LMM awhile back, in which the LMM assembly code has to be arranged in hub memory in reverse order:
instr2        long      0-0
              rdlong    instr1,pc
              sub       pc,#7
instr1        long      0-0
start_here    rdlong    instr2,pc
              djnz      pc,#instr2
Reverse LMM code runs a lot faster as a result, but it's a real pain to write and debug. The reason the code has to be in reverse is that there's no ijnz instruction to complement djnz. Unfortunately, djnz is the only instruction in the Propeller's instruction set that both modifies a destination value by adding or subtracting and which causes a jump to occur. So it seemed that the reverse LMM was it, as far as hitting the sweet spot was concerned.
Today I was determined to find a way to do a fast forward LMM. I've learned that, with the Propeller, virtually anything is possible, and this turned out to be no exception. The secret is to fetch the instructions out of order but to execute them in order. This is done with a pipeline of sorts and takes advantage of the Propeller's own pipelining. Here's the basic loop:
flush         add       pc,#4                   'Get next instruction address.
              rdlong    instr2,pc               'Preload pipe with next instruciton.
              sub       pc,#1                   'Point back to first instr, plus 3 bytes.
pipe          rdlong    instr1,pc               'Read PC instruction.
              add       pc,#9                   'Point to PC+3 instruction.
instr1        long      0-0                     'Execute PC instruction.
              rdlong    instr2,pc               'Read PC+3 instruction.
instr2        long      0-0                     'Execute PC+1 instruction.
              djnz      pc,#pipe                'Point to PC+2 instruction.
Every time through the loop the PC jumps ahead by 9 bytes, then back by 1, for a net gain of 8 bytes, or two instructions. For the first instruction in the loop, the PC points to the actual long address, plus 3. It then increments the address by 9, thus pointing 12 bytes, or 3 instructions away. Then it executes the first instruction. The next step is to fetch the instruction three instructions away from the one it just executed. But before it can be stored in instr2, the Propeller fetches the instruction previously loaded there and executes it. This is the effect of the Propeller's pipelining. Finally, by using a djnz, the instruction two instructions from the first one is pointed to and fetched at the beginning of the loop. So, to summarize, in a program sequence denoted "ABCDEFGHIJ", the instructions are fetched in the order "BADCFEHGJI" but executed in the order "ABCDEFGHIJ".
One downside to this scheme is that the value of the PC does not change between instr1 and instr2. This makes it impossible to implement a simple add pc,#daddr for relative jumps, since you don't know in which slot it will be executed and, consequently, can't tell what the value of the PC is relative to the jump. For that reason, every jump has to be a long jump, with the jump address in the next long.
Here's a program that I used to test and compare this fast LMM with the normal one — both using long jumps:
CON
   _clkmode       = xtal1 + pll16x
   _xinfreq       = 5_000_000
PUB  Start | rslt
  cognew(@fast_lmm, @test_code)
DAT
'-------[noparse][[/noparse]Normal LMM Kernel]--------------------------------------------------
              org       0
norm_lmm      mov       nbase_addr,par          'Get the base address of the code.
              mov       npc,par                 'PC is base address to start.
lmm_loop      rdlong    instr,npc               'Read the next instruction.
              add       npc,#4                  'Increment the PC.
njump         rdlong    npc,npc                 'Long jump: address in next instr.
              add       npc,nbase_addr          'Add relative address to base address.
              jmp       #lmm_loop               'Resume with new address.
njump_ret     long      0-0                     'Dummy needed to accommodate CALL.
nbase_addr    res       1
npc           res       1
'-------[noparse][[/noparse]Fast LMM Kernel]----------------------------------------------------
              org       0
fast_lmm      mov       fbase_addr,par          'Get the base address of the code.
              mov       fpc,par                 'PC is base address to start.
flush         add       fpc,#4                  'Get next instruction address.
              rdlong    instr2,fpc              'Preload pipe with next instruciton.
              sub       fpc,#1                  'Point back to first instr, plus 3 bytes.
pipe          rdlong    instr1,fpc              'Read PC instruction.
              add       fpc,#9                  'Point to PC+3 instruction.
              rdlong    instr2,fpc              'Read PC+3 instruction.
              djnz      fpc,#pipe               'Point to PC+2 instruction.
fjump         cmp       fjump_ret,#instr1+1 wz  'Where did the CALL come from?
        if_z  mov       fpc,instr2              '  instr1: Jump target is in instr2
        if_nz sub       fpc,#1                  '  instr2: Need to read jump target from hub.
        if_nz rdlong    fpc,fpc                 '          Get it.
              add       fpc,fbase_addr          'Add base address.
              jmp       #flush                  'Go back and restart the pipeline.
fjump_ret     long      0-0                     'Contains address of the CALL. (Do not use RET!)
fbase_addr    res       1
fpc           res       1
'-------[noparse][[/noparse]LMM Test Code]--------------------------------------------------------
              org       0
test_code     mov       dira,#7
:loop         mov       outa,#1
              mov       outa,#2
              mov       outa,#3
              mov       outa,#4
              mov       outa,#5
              mov       outa,#6
              mov       outa,#7
              mov       outa,#0
              nop                              'Added to ensure worst case for jump in fast LMM.
              call      #fjump                 'Change to #njump for normal LMM.
              long      :loop << 2
Here is what the scope output looked like for the normal LMM:
The total length of the loop was 4.00µs. Here's the same test program run with the fast LMM kernel:
Now the total length of the loop is 2.80µs, for a 42.8% speedup. Although the fast LMM goes twice as fast on the straightaway, it's slower in the turns, due to its more complicated gear shifting.
One other thing to notice is that individual instruction times in the fast LMM vary, depending on whether they are executed in instr1 or instr2. This will have consequences when output timings are critical.
Addendum: I just realized that this version has one huge, and fatal, flaw. That would be the use of the z flag in the jump routine. Setting flags is a big no-no in LMM kernels, since doing so will interfere with their use in the users' code. As such, the improved kernel code (below) is recommended instead.
Post Edited (Phil Pilgrim (PhiPi)) : 8/4/2009 6:19:29 PM GMT
640 x 480 - 15K
640 x 480 - 15K
  • RossHRossH Posts: 5,775
    edited 2009-08-03 00:50
    Phil,
    You continue to amaze me. Your brain must work equally well backwards, forwards, sideways and time-sliced smile.gif
    I'm currently reworking my XMM kernel to fit in the new Catalina memory model (i.e. 16Mb data/code/heap, with 32kb stack). It's a struggle because I'm just a few longs short.
    Now I'll have to re-write it again and try and find even more space. If you don't stop doing this, I swear I'm going to come over there and confiscate your Propeller nono.gif
    Ross.
    Catalina - a FREE C compiler for the Propeller - see Catalina
    edited 2009-08-03 01:04
    Phil Pilgrim (PhiPi) said...
    WOW!
    Very impressive work.
    My brain hurts a bit, thinking through it, but still... impressive speedup.
    For comparisons sake, what does your scope show with my recommended 4 way unrolled loop?
    Very very cool work...
    Bill
    Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    Morpheus & Mem+ Advanced dual Propeller SBC with XMM and 256 Color VGA - PCB, kit, A&T available NOW!
    www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
  • jazzedjazzed Posts: 11,803
    edited 2009-08-03 02:54
    Sweet [noparse]:)[/noparse] Less than 1/10th reversed [noparse]:)[/noparse] Not falling out of the window is a big win. Good work Phil.
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
  • heaterheater Posts: 3,370
    edited 2009-08-03 07:34
    Good grief Phil!
    That's impossible to follow first thing after waking up in the morning bleary-eyed and bleary-brained.
    Reminds me of when I attended the UK launch presentation of Intel's i860. With it's parallel execution of integer and float ops, its pipelined execution, its assortment of multiply-add style instructions. It could hit 66 MFLOPS (huge at the time) only problem was Intel did not know how to code it to do that. Took another company to show them !
    Looks like you might have just saved my one cog 6809 emulation. Currently it uses a lot of overlays to run op emulation codes which are mostly straight line (no bends to slow down). This could save the space used for overlay loading, which is very tight now, and give a tad of a speed gain.
    Time for some experiments.
  • BaggersBaggers Posts: 3,019
    edited 2009-08-03 08:21
    Phil, that's a great speedup [noparse];)[/noparse]
    As for timing critical stuff, you could always jump back to normal LMM for that section! [noparse]:D[/noparse]
    http://www.propgfx.co.uk/forum/·home of the PropGFX Lite
    edited 2009-08-03 11:53
    · Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
    · Search the Propeller forums (via Google)
    edited 2009-08-03 12:54
    Cluso: What do you reckon, is this up to speed with the overlay loader?
    For "straight line" code that is, overlays will surely be quicker if there are tight loops in there.
    edited 2009-08-03 18:13
    Phil,
    At first I "got it" but in the morning before a cup o' joe I was suffering riddle amnesia. What is wrong with the following picture?
    In the first line is the Bill's original LMM kernel, very straightforward steps by 4 through the longs in the hub.
    Second is the picture you have painted for the "not reversed" fast LMM. Leapfroging in the RDs but sequential in execution.
    Now the dilemma, a source of confusion for the bleary eyed. Third is the actual calculation of the PC, which involves pointing to the last byte of a long, not the first byte, correct? Does this work because the Prop automatically truncates the address of a long so that the RDLONG does in fact fetch the correct long and not some weird offset value?
    Forth in the diagram is the reverse model, same issue.
    Tracy Allen
    www.emesystems.com
    313 x 275 - 5K
    edited 2009-08-03 18:15
    Tracy Allen said...
    Yes, that's exactly what happens.
    edited 2009-08-03 22:29
    I tweaked the fast_lmm code a little so that jumps would not have to use rdlong to get the target address. This speeds the loop execution to 3.40µs from 3.60µs compared to a slightly improved version of the old code, which took 3.80µs. But it comes at a price: the jump target has to be included twice after the call to fjump. This ensures that the jump target is always loaded into instr2 when fjump is called — even when it's called from instr2. In the case of a conditional jump not taken, this equates to two nops. Here's the new test program with the prior (3.60µs) improvement commented out:
    CON
    PUB  Start | rslt
    DAT
                  org       0
    nbase_addr    res       1
    npc           res       1
    '-------[noparse][[/noparse]Quad LMM Kernel]----------------------------------------------------
                  org       0
    quad_lmm      mov       qbase_addr,par          'Get the base address of the code.
                  mov       qpc,par                 'PC is base address to start.
    qlmm_loop     rdlong    instra,qpc              'Read the next instruction.
                  add       qpc,#4                  'Increment the PC.
    instra        long      0-0                     'Execute the instruction.
                  rdlong    instrb,qpc              'Read the next instruction.
    instrb        long      0-0                     'Execute the instruction.
                  rdlong    instrc,qpc              'Read the next instruction.
    instrc        long      0-0                     'Execute the instruction.
                  rdlong    instrd,qpc              'Read the next instruction.
    instrd        long      0-0                     'Execute the instruction.
                  jmp       #qlmm_loop              'Loop back for next instruction.
    qjump         rdlong    qpc,qpc                 'Long jump: address in next instr.
                  add       qpc,qbase_addr          'Add relative address to base address.
                  jmp       #qlmm_loop              'Resume with new address.
    qjump_ret     long      0-0                     'Dummy needed to accommodate CALL.
    qbase_addr    res       1
    qpc           res       1
                  org       0
                  add       fbase_addr,#4           'Pre increment to second instruction.
                  mov       fpc,fbase_addr          'PC is base address to start.
    flush         rdlong    instr2,fpc              'Preload pipe with second instruciton.
    fjump         mov       fpc,instr2
                  add       fpc,fbase_addr
                  jmp       #flush
    { Old (improved) fjump code.
      End of old fjump code. }
    fbase_addr    res       1
    fpc           res       1
                  org       0
    :loop         mov       outa,#1
                  mov       outa,#2
                  mov       outa,#3
                  mov       outa,#4
                  mov       outa,#5
                  mov       outa,#6
                  mov       outa,#7
                  mov       outa,#0
                  nop                              'Kept in for accurate comparison with prior tests.
                  call      #fjump                 'Change to #njump for normal LMM; #qjump for quad LMM.
                  long      :loop<<2,:loop<<2      'Need to include loop target twice.
    Here's an image of the test results for the fast LMM:
    Here's the same program run with Bill's quad LMM:
    The fast LMM is faster in the straightaway, with the quad LMM showing a slight (50ns) advantage in the turns.
    640 x 480 - 15K
    640 x 480 - 15K
    edited 2009-08-03 22:44
    As always, very nice work Phil!
    edited 2009-08-04 01:41
    @heater: My Overlay Loader is based on Phil's reverse code. It is optimised so that it hits the sweet spot, so it will be 20% slower that LMM plus the actual calling overhead for inline code. However, if there is any looping code, then it will blit the LMM code. The loading mechanism is optimised at comple time, so there is minimal calling overhead. For example, the last address is pointed to. There is no length to decrement as the last long loaded will overwrite the jump in the loop and will immediately execute the overlaid code.
    So in essence, I would expect Overlay code to be faster in overall execution than LMM because code inherrently has loops and this is where Overlays shines. However, Overlay coding is more complex than LMM as it has to fit within a sub-block in the cog. Therefore, there is no doubt a place for both systems.
    Now, knowing what you are after for emulations, I would expect that LMM will definately have its place in the emulator where code is inline, as will overlays where loops are used. The LMM only takes a few longs anyway. So, I would expect you should use both methods.
    edited 2009-08-04 05:39
    Clusso: In the Z80 emulator we were very short of space so many ops were emulated with code overlays, fortunately in the CP/M world most of those overlaid ops are never used so we have no qualms about it. The base 8080 set of ops is in native full speed PASM. Could have been done in LMM. The old Z80 emulator used reversed LMM which I did not want to do again, the overlays are quicker than normal LMM and everything now fits in one COG so all is well.
    The MoCog 6809 emulator is VERY tight on space. Already it has many overlaid ops. In fact I've stopped work on it for a long while as it looks like it won't fit, there is so much code that needs to be "resident".
    So, I was looking at this new LMM technique as a way of saving space, the overlay area in COG is no longer required, whilst at the same time having comparable speed. It helps that most of the code that would be LMMed is "straight line ", loop free.
    However, the issue is that, unlike Z80, all 6809 ops are heavily used so overlays or LMM are a real speed killer.
    Yesterday I woke up with a possible solution in mind:
    1) Forget overlays and LMM and the single COG goal.
    2) Load all the functions that are currently overlaid into a second COG with a small loop of code that is looking for commands from the first COG.
    3) Arrange that our op vector table can vector us to those routines in the second COG and command it to go.
    BINGO the equivalent of overlays put they are all preloaded into the second COG waiting for "remote" invocation.
    This is now a topic for another thread.
    edited 2009-08-04 10:30
    I have thought that would be the overall solution for a long time. SOmehow I thought we had discussed it. We have spare cogs available with the seperate prop concept and I am certain this is the way to go. There are ways we can get the other cogs to work quickly. Just time limited and I really want to get the RamBlade and TwinBlade out, and get documentation fixed for the TriBlade.
    edited 2009-08-04 12:35
    Clusso: Yes we have discussed multi-cog emulation. and I did build a multi-cog Z80 emulator only it was eating cogs for no speed gain.
    That multi-cog approach relied on all COGs inspecting all opcodes and the ones who could do the work did it.
    Now it occurs to me that we should be able to load a bunch of opcode handlers into a second COG and have the first COGs dispatcher decode the op-codes and get the address in the second COG of the required handler from the dispatch table. Then stuff that vector somewhere for the second COG to pick up and run with.
    Sort of a COG to COG procedure call, the single dispatch table look up can find a vector to a procedure in the current COG or another one. No duplicate decoding and such going on, not much time wasted in handing over from COG to COG. A lot less than loading an overlay anyway.
    Not sure if we have discussed that idea before.
    I don
    edited 2009-08-04 12:51
    Heater: That was exactly what I was thinking and had thought I had discussed with you. I knew the multi cog approach failed, but always thought there were other ways to run another cog to do certain code without the overhead.
    The best way is to get your 6809 emulator running properly. Hopefully by then I will have time to help you get it running fast smile.gif
    edited 2009-08-04 14:34
    Ah but, I'm not sure I can get it running properly without some drastic LMM or second COG changes. I'm pretty much out of "resident" space in the COG and I need to add a fair bit more.
    I don't remember any such discussion, but then I have a lot of gray hair as well...
    Anyway this will take a while as I'm pretty busy now, just time to ponder it occasionally.
    edited 2009-08-04 14:55
    Could be my senior moments too !
    Anyway, just put the code in overlays for now when you get time. Maybe we can chat later when I have time as well.
    edited 2009-08-04 16:15
    I've added an important note in the top post regarding the original version, in case someone is tempted to use it.
    edited 2012-12-09 23:45
    For the record, the Fast LMM Kernel without flag usage:
    '-------[Fast LMM Kernel]----------------------------------------------------
                    org     0
                    add     fbase_addr,#4
    flush           add     fpc,fbase_addr          'PC is base address to start.
    fjump           add     fjump_ret,#one-(instr1+1)
                    jmp     fjump_ret
    fjump_ret       long    0-0                     'instr1+1 or instr2+1
    ' two - one == (instr2+1) - (instr1+1)
    one             mov     fpc,instr2
                    jmp     #flush
    two             sub     fpc,#1
                    rdlong  fpc,fpc
                    jmp     #flush
    fpc             long    0
    fbase_addr      res     1
                    fit
    And while I'm at it, a counter version as well:
    org     0
    ctrx_lmm        movi    ctrb, #%0_11111_000     ' LOGIC always
                    mov     frqb, #1
    eins {embedded} call    #cjump                  '  -4
    _one            rdlong  eins, phsb              '  +0 = base + 6f
    zwei {embedded} long    0                       '  +8
    _two            add     phsb, #8                '  -4
    main            rdlong  zwei, phsb              '  +0 = base + 2f
                    tjnz    phsb, #eins wr          '  +8
                                                    '                      eins    zwei
    cjump           xor     cjump_ret, #_one ^ _two '       swap targets    +0 =    -4
                    sub     cjump_ret, #1           '       final source    +4      +0 =
                    mov     phsb, par               '       base address    +8      +4
    cjump_ret       add     phsb, 0-0               '       +offset         -4      +8
                    rdlong  eins, phsb              '  +0 = insn at jump target
                    add     phsb, #4                '  +8
                    tjnz    phsb, #main wr          '  -4
                    fit
  • BeanBean Posts: 8,129
    edited 2012-12-10 04:58
    Forgive me, but what is the purpose of the "tjnz phsb, #main wr" instructions ?
    I assume is has something to do with the phsb shadow register, but I can't puzzle out how it is being used.
    Bean
    edited 2012-12-10 05:41
    Bean wrote: »
    ... what is the purpose of the "tjnz phsb, #main wr" instructions ?
    Just have a look at the naked LMM loop:
    DAT
    eins            nop                             '  -4
    _one            [COLOR="blue"]rdlong  eins, phsb[/COLOR]              '  +0 = base + 6f
    zwei            nop                             '  +8
    main            [COLOR="#FFA500"]rdlong  zwei, phsb[/COLOR]              '  +0 = base + 2f
    The code is setup so that the actual LMM insn fetch starts with the second rdlong. Lets also assume that phsb is set to some non-zero 4n address. This means - as indicated by the comment - that the insn is read from base_4n + 2*frqb (which for a rdlong equals base_4n). Now assume for a moment that the tjnz is a normal jump insn. At the time we execute the first rdlong phsb would be base_4n + (2+16)*frqb (next hub window). Which is not what we want. Put back the tjnz. Because shadow[phsb] is non-zero we still get the jump, OK. Writing the result (wr) will update shadow[phsb] with itself (base_4n). This also resets counter[phsb] to base_4n in the last cycle of tjnz. IOW now the first rdlong will read the next insn from base_4n + 6*frqb (effectively base_4n + 4). From there we simply add 8 to the base address and do this all again.
    Note, the default for tj[n]z is nr.
    Testing Kuroneko's fast_lmm against my version in post #11 (which also doesn't use flags), yields 1060 ns for the fjump vs. 880 ns for mine. Kuroneko's is cleaner, though, since it doesn't require two copies of the jump target. I tried his ctrx_lmm, too. Its cjump matched my fjump's 880 ns, but without the doubled jump target.
    Nicely done, Kuroneko-san!
