Help Minimum voltage for pulsin ?
In DC my incoming square wave goes between 1.2v to 5.3v
In AC I have measure Vpp=3.9v but also as low as 3.17v
I have noticed that in some cases the input frequency is not properly detected..
Just wondering how pulsin works.. ie what is the min and max it will work with ?
or is it purely based on votage difference in which case what Vpp will it fail ?
Post Edited (agfa) : 8/2/2009 12:59:04 PM GMT
So you are saying if my 1.2v DC Low goes over 1.4v then it would register as a HIGH also...!!
seems like I need to reduce my signal by about 1v so that the signal ranges from 0.2v to 3.5v (assuming a 3.5v high would give a reliable Hi Reading ?)
My electrical skills are very minimal... Could I just make a simple voltage divider to reduce the voltage ?
Take a look a TTL logic!
_______$WMc%_________
The Truth is out there············································ BoogerWoods, FL. USA
I had a project that I need to do something along the same line
and if you have ac or dc then you could something like H11AA1
Here is the data sheet
http://www.vishay.com/docs/83608/83608.pdf
and here where you can buy some
http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMteimceiIVCB1Lm4ynvmRGvs%252bwYP8Brkno%3d
you can put a pot on the out put to adj you max voltage
If you need a drawing of how to do this let me know
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 8/3/2009 2:18:17 AM GMT
YES PLEASE with the Diagram !!
Heres the link I was trying to find.
·http://www.parallax.com/Portals/0/Downloads/docs/books/edu/RoboticsV2_2.pdf
www.youtube.com/watch?v=P4Edv-Oc3SQ
No worries.. will try to get the signal conditioned better for the 1.4v threshold. (ref page 210 of robotics pdf)
If it doesnt work I may have to use the opticoupler if I can figure it out.
Post Edited (jbalat) : 8/4/2009 11:55:47 PM GMT
