sensing tilt in two axis using inclinometers
                    I am using a dual axis mems based accelerometer... The problem is that I want to find two axis tilt for a platform that has two degrees of freedom...but while using accelerometer to find tilt the problem is that if there is already a tilt in one axis the other axis shows incorrect tilt..
Is there any mathematical solution to the same....
The angles PHI and RHO are the angles that the X and Y accelerometer axes make with the fixed reference XY plane. When the sensor is horizontal, both Ax, Ay are zero, so are PHI and RHO. Basic tilt angles can be generated from the accelerometer outputs using the next equations since the X- and Y-axes follow the sine function. It should be noted that these angles are not (!) the pitch and roll angles typically used in aeronautics, nor are they the direction cosine angles for describing which direction a vector is pointing. When g = 1·
PHI = ARCSIN(Ax)
RHO = ARCSIN(Ay)
Better to use 3-axis accelerometer for tilt sensing, as you can combine the Z-axis data to obtain maximum and uniform·sensitivity.
PHI = ARCTAN(Ax/SQRT(Ay*Ay+Az*Az))
RHO = ARCTAN(Ay/SQRT(Ay*Ay+Az*Az))
By monitoring the sign of the Z-axis output, you can tell which quadrant the accelerometer is being
tilted, consequently indicating inversion. The next table shows the expected signs for he X-axis and the Z-axis in each quadrant.
Quadrant·· Ax······ Az
·· 1·········· +······· +
·· 2········· ·+······· -
·· 3··········· -······· -
·· 4··········· -······· +
And, of course, all these are valid only when your sensor is at rest.
Cheers,
Istvan
