Parallax microproccessor with tuner...
I'm Developing Digital box with Tuner build in using Parallax mp, i'm confuse in matching tuner that completely match with parallax...
Anyone had any experience in this topic...
thanks Before...
thanks Before...
The Propeller runs off a 3.3V supply and has I/O pins that use 3.3V logic levels, so anything designed for 3.3V logic levels can be connected directly or sometimes via a small series resistor (150 Ohm to 330 Ohm typically) for protection from accidental short circuits. Other voltage levels will require some kind of interfacing depending on the circumstances.
I have project building Interactive Tv STB,the STB must have Video out, Ethernet and Tuner in. the idea is the STB have Menu interactive and for the tv channel, the STB have Tuner Inside active when the number of menu selected. For Example sub menu TV channel :
1. CNN -> selected then tuner active selecting freq CNN trought tuner.
2. HBO
3. Etc
can u guide me for the match product?
I found Ybox2, but no tuner inside...
or u have another suggestion?
Thank U in Advanced
