Making a Follow Me BOE-Bot. Wanna Play??
I'll be making a Follow Me Robot for demo purposes in my electronics/robotics classes.
I expect to build it in phases, and clearly document it all so that others can follow along or build it later.
Phase 1:
- Robot runs around occasionally changing direction randomly.
- Whiskers for obstruction detection
Phase 2:
- Add I/R near detection, either the BOE-Bot IR or maybe sharp sensors.
Phase 3:
- Add Ping))) sensor for object avoidance.
Phase 4:
- Put Ping on a servo and program Ping to look for clearest path around obstacles.
Phase 5:
- Program BOE-Bot to follow me around the school. Probably using RF transmitter/receiver.
Eventually I will scale this up to a cart that carries all my books and papers around the campus.
If anyone wants to build one of these along with me, let me know. Otherwise, I'll post the phases on my web site as they get completed.
http://www.RichardVannoy.info
RoboticsProfessor@gmail.com
Richard Vannoy
Programming and Electronics Instructor
Phase 1:
Phase 2:
Phase 3:
Phase 4:
Phase 5:
Richard Vannoy
I was thinking that I could wear a hat with an IR beacon that continuously sends out a code, a code which I could modify to alter the behavior of the bot. I think that is the easier part.
For sensing I was planning to use an array of 16 IR sensors arranged in a circle. Each IR sensor has a field of view of about 50 degrees. Depending on which sensors pick up the signal it could determine my bearing with accuracy to 15 degrees. If another array was mounted 2 ft away it could also get a course range measurement.
The goal is to have a robot that will follow me, and only me, at a set distance. It needs to be able to cope with obstacle avoidance, especially people walking past it.
Do you think my approach is feasible? I'm trying to avoid using moving parts.
Rich H
http://forums.parallax.com/showthread.php?p=824347
I am very interested in the follow me aspect also. Right now the SuperBOE)))is autonomous using the roaming PING and IR via 1 program and remote control via another program. I want to add one more program for "Follow me" and combine all three programs into one if possible. I understand I might need to upgrade to a different stamp with more speed and memory or add multiple stamps for handling each program.
Lets talk!!!!
I'm still debating/researching the technology for the robot to use to follow me. Seems like the best choices are IR or RF.
IR sounds good but it is pretty much line-of-sight. I would really like the robot to be able to follow if I leave the classroom and go to my office. With IR, I have to keep the robot in sight. (Which wouldn't be a big deal.) I suspect a coded pulse would be necessary to eliminate other sources.
Several sites are now selling a reasonably priced radio frequency transmitter/receiver pair suitable for robots.
The advantage to RF is that I can turn a corner or be on the other side of a wall and the robot will still try to approach me.
Both methods have problems with bad or confusing reflections. I have a student team working with the new RF modules, so I'll know more about RF soon.
My "large" platform is a three-foot high, three-shelf audio/video cart that is typical in schools. I'm also thinking about wheel chair parts for power and motors.
Richard Vannoy
My interpretation of "follow me" for a robot is much the same as for a human. If the human loses sight of the person they are supposed to follow then they have to make a decision on what to do next. They may choose to continue on to the last known location, make a guess on which way to head based on where they just were, or just stop and wait for help. Turning corners and disappearing from sight just isn't fair unless your destination is already known to the follower. When I tell my robot to follow me, I will have to make sure that I don't lose it - much the same way as when I tell a human to follow me.
For your purposes it seems that the "follow me" as I have described it would work just fine. If the robot did lose you it could decide which room it should go to based upon the time of day. Or you could send it a message via RF that says "come to my office", that's assuming it would know how to get there.
Rich H
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/rf/List/0/SortField/4/ProductID/111/Default.aspx
My students have the idea of putting the receiver inside a baffle, making it somewhat directional. If the robot does a 360 degree turn, it should be able to detect a stronger signal in one direction. Then the robot can turn, head in that direction, and change behavior (search again) if the signal degrades or is lost.
The jump between 1) "Search for a signal and head in the direction where it seems strongest." and 2) "Find the teacher somewhere in the building, and go to his desk if you get lost" is significant. I'm sure the BOE-Bot, on it's own, can't handle the processing power and mapping of option 2. For now I'd stick with line-of-sight and maybe later add the computing power needed for mapping.
One student wants to use a PC and write code in Python to make a visible map on the screen and track the robot throughout the building. The PC, in this way could assist the robot in getting around.
Richard Vannoy
PG
Post Edited (Pi Guy) : 8/1/2009 9:55:08 PM GMT
As in those LED flashing shoes all the kids have worn to the point they're already going out of style. Just tune the bot to the flashing sequence ?
PG
PG
