Detecting a pulsed laser in daylight
I have been asked to look at a project that will have many laser guns(<255) with many targets (~128) I just got clarification that this will be set up in daylight conditions, each gun will transmit its ID on the laser in Sony IR format to the receiver on the target, it was originally going to be indoors in dimly lit conditions, outdoor with high light conditions i now cant use a simple photoresistor, does anyone have any ideas on how to reliably pickup the laser in high light conditions?
Jimmy
Jimmy
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Is it a visible or infrared laser? Which wavelength? There's Fairchild detectors that are very discriminating. If infrared, these detectors will do the job, if visible (presumably red), you will need light filtering of wavelengths other than of your laser.
Cheers,
Alex
Sheild the detector with a black painted tube - a piece of cheap PVC pipe works great.
What color/frequency are the lasers to be?
Does rain matter? (Heavy rain will cut the beams and potentially cause false signal pulses, or disrupt things entirely.)
- Howard
filter the IR-signal.
Photoresitsors are reacting very slow. You should use phototransistors as a minimum
take a look into the datasheet of this
Infrared Receiver
which wavelength sensivity it has at your lasers wavelength
best regards
Stefan
650nm for the red lasers
532nm for the GREEN lasers
I dont think tubes will work, that will make them have to shoot the targets dead on, they want a decent shooting angle.
They will not be used in rain conditions
@Stefan: Yes, I am looking at phototransistors now
EDIT: Whoops I meant to say GREEN, not red twice
Post Edited (Jimmy W.) : 8/1/2009 5:13:33 PM GMT
You would like to detect from a distance, yes? A 100 m or, so. Start to check our good friends, the sensitive laser detectors in cars, then.
In your application, I think, ·lasers are (should be) in the infrared region to be eye-safe. Look for TAOS new, higly sensitive light detector chip the TSL237. Its spectral range from 320 to 1050 nm is maybe not optimal for those IR lasers, but it is perhaps good enough on the spectral edges. A 2D 'bull's eye' array· of those small sensors, where their signals can be correlated with the Propeller (yes, in DSP mode with high speed fixed-poin math) should be very responsive.
When your lasers are really in the red (630 nm), those TSL237 patches wil be the most sensitive (top at 700 nm), but for the light of the environment, too. Apply narroband(!) flexible red filter foils on the detector's fabric to improve S/N for the (hopefully) slightly diverging beams.
Or, choose a photodiode-amplifier hybrid with filter to be more cute. At the extremes you can use Peltier cooling of the device. The whole thing packs within a 1-2 cubic cm, and can be constructed durable for on-field application. Again, DSP will be necessary to pick out the signal from the cluttered radiation of the environment. I guess, to sense from 1-2 km, or from even farther, is realistic with that.
You can even build a laser distance·sensor for several km·with such a sensor + optics. The Prop·can handle those timings easily. ·A laser signal, reflecting back from·1.5 km, travels for about 10 usec. Counting a 120 MHz pulse wave from the shot until the echo, gives 1200 counts.· So, resolution is about 1-2 m with that counter in a COG. Or just take the difference of CNT readings, to make life easier.
If you accept help and assistance·in programming, let me know. A few free games will be enough for me.
Cheers,
Istvan
Post Edited (cessnapilot) : 8/1/2009 1:52:39 PM GMT
Any idea where to get these filters? We are going with red laser @ 650nm and green @ 532nm, the teams will only be able to shoot the correct targets so filtering will be a bonus. Looking @ TSL237 it looks like these are light to frequency devices, I am going to be modulating the laser to send a byte in sony format to the target to identify which gun shot it. I guess there are way to still decode the signal if that were the case.
Jimmy
You can use standard photosensors from Fairchilds, Optex, Panasonic, etc. Then you have to deal with the electronics and mounting. It may sound a bit odd at first but have a look at IF-D93 from Industrial Fiberoptics. On Digikey, p/n is FB122-ND with datasheet. I've used these components both for inexpensive on-site plastic fiberoptics links and also for other goodies. Completely plastic, easy to cut, modify, adapt, and install in custom enclosures. There's even a mounting screw hole. They are sensitive photodarlington designed for transmission through plastic fiber optics in visible and IR. The inner male mating is easy to break and that would leave you with a flush surface in front of the photosensor where you could glue your optical filter. Plastic-on-plastic is very easy to glue. Anyway, that's how I would do it. As for your modulation question, these parts are intrinsically designed for modulated light signals!
Cheers,
Alex
Post Edited (4Alex) : 8/1/2009 7:42:20 PM GMT
Without shielding the sensors from direct sunlight, you will have some real problems with sensor saturation. Once the sensor reaches its maximum output due to too much light, you will not be able to detect any modulation riding atop the ambient light.
One thing to keep in mind is that laser beams spread over long distances, whereas bullets do not. Therefore, you will likely record many more "bulleyes" with a laser than with real ammo.
At the start the the day all targets and guns are on a common charging/data bus, they get all their RTC clocks synced up, the worst case scenario is the target cannot decode the ID, and has to ask the main processor via zigbee who shot within a few ms of it getting shot and then doing catchup and logging the data.
I am thinking about using some cheap programmables to do ADC and noise filtering and then shooting back data to the prop, I am going to see how to lay that out.
@Cessna, "blue on blue" targets would get stopped by the filter now, counting a total miss.
Jimmy
This can be very cheap to build; you'll need a curved mirror that will reflect IR or whatever colors you use; a·prism or grating that can pass those colors; a piece of pipe to separate the prism or grating from the detector; and the detector itself, which will be by a considerable margin the most costly part.
The longer the pipe (or other tube) separating the prism/grating·from the detector, the greater your wavelength/frequency selectivity will be.
You can even put the curved reflector out somewhere by itself and aim the spectrograph at it from a distance.
All this is brainstorming, of course; actually I have no expertise at all in building such stuff.
· -- Carl, nn5i@arrl.net
