servo functions and limitations
Hello all [noparse]:)[/noparse]
i have a small dilemma dealing with a servo and their limitations...
i have a BSX that is running the majority of a project but have to result to manual switching due to the variables (i don't know if the servo will work) of a motor.· i would like to make the whole project to be ran from the stamp but i would need to know if the servo could oscillate at 10-50 Hz while moving a 90 gm piston and 120 gm of water for a distance of 4cm onto a reservoir.·
key factor making the stamp drive an optocoupled (parallax)servo to oscillate 10-50 Hz (tunable) without making the servo decrease the life-span drastically.
help would be greatly appreciated [noparse]:)[/noparse]
- Stephen
i'm glad i posted the question before finding out about the gears [noparse]:)[/noparse]) so thank you!!
any help would be greatly appreciated.
i have a conventional motor moving a "locomotive-wheel" to get the same aeffect that a servo or stepper motor would be able to do (but in a far more controllable way); the way it's rigged at teh moment is very inneficient due to the gearing that has to be used along with a clutch, resistors and an itchy trigger finger [noparse]:([/noparse]
thanks again!
I think a solenoid would work better. Think about it.
_________$WMc%________
The Truth is out there············································ BoogerWoods, FL. USA
can you (if you know, wouldn't want you to search) suggest a solenoid that could fit in an enclosure the size of an Ipod (3x5x3) and run on less than 12VDC?
Thats a good one.
Other then goggle, I don't know!
_______$WMc%____
i started to wind a custom solenoid for this applicaiton, if it works i'll definitelly post my results. i just didn't know how difficult it would be to do all from scratch. searched in google for about 4.5 hrs and found very little hope, which is why i'm spooling copper on a nail [noparse];)[/noparse]
but thanks for the insights and getting the gears grinding to a different speed [noparse]:)[/noparse]
if you happen to come accross a 1oz-pull 3-8vdc solenoid.... pleaaaassse let me know [noparse]:)[/noparse]
Perhaps a peristaltic pump driven by a continuous-rotation servo or a small gearmotor/steppermotor?
en.wikipedia.org/wiki/Peristaltic_pump
www.instructables.com/id/recirculating-gravy-fountain/
Perhaps a re-purposed aquarium diaphragm pump? They are typically solenoid driven (but at 110 VACfirst link below is for a battery operated one).
www.drsfostersmith.com/product/prod_display.cfm?pcatid=3693&cmpid=03csepg&ref=3475&subref=AA&srccode=cii_5784816&cpncode=17-34656634-2
www.patentstorm.us/patents/6164932.html
Daniel
greatly appreciate the help fellas!!!
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320396615160&ssPageName=STRK:MEWNX:IT
